Revo 1/5 scale on road project
ABP
Revo 1/5 scale on road project - 08.07.2010, 11:03 AM
Hy there... for the first sorry my bad english.
I saw this thread of a 1/5 on road car made from traxxas parts... http://www.rccrawler.com/forum/showthread.php?t=145172
This is a video of what I hope to get http://www.youtube.com/watch?v=lGm-tL2xGvs
The motor will be a 2800kv 36mm74mm http://www.hobbycity.com/hobbyking/s...hless_Inrunner
The esc is a hobbyking 150A http://www.hobbycity.com/hobbyking/s...dProduct=10370
Two 3s 5000 turnigy
13 cm diameter on road wheels
Now I want to make a sway bar for the front axel.
What do you think of the motor?
If i get 100km/h im a happy guy
ID:	9224   Click image for larger version
ID:	9225   Click image for larger version
ABP
08.07.2010, 11:04 AM
ID:	9228   Click image for larger version
brushlessboy16
brushlessboy16's Avatar
08.07.2010, 05:33 PM
Motor is not gonna last long.. way too much rpm..
08.07.2010, 06:37 PM
If he runs it on 3s... Yeh, needs to go to a 1600kv motor for 6s.
Dj_Sparky
08.07.2010, 06:40 PM
If you can afford it, you should get this or lower kv: http://www.hobbycity.com/hobbyking/s...hless_Inrunner
Will the HK 150A ESC handle 6s fine? It says it's rated for 2-4s... ?
08.07.2010, 09:35 PM
That motor has a 6mm shaft. Pinions for it are more difficult to find. Since he is running a revo tranny he will use plastic spurs and can use non-hardened pinions. So he could drill out a 5mm pinion, but almost all of the 5mm pinions are hardened.
I like the kb motors, plenty of power. Ran a few of the L cans in on road cars, geared for 55mph and they did just fine, 4s setups too. On 6s with the right gearing and good lipos I see no reason he could not do 62mph (100kpm). I would use a MMM, we know they work.
ABP
08.08.2010, 06:34 AM
Yep I will use 3 s lipo....the two packs will be connected in parallel.
And I want to stik with the KD motor because I saw a savage converted to brushless with that motor and it just fly!!enought speed for me... and this revo will be more lighter than that savage so it will accelerate and go faster...
I found a nice m3 boddy on ebay and if i don`t find something else I will buy it.
The project will be done in december because of lack of funds.
nitrostarter
nitrostarter's Avatar
08.08.2010, 07:45 AM
That 2800kv motor will not push a 1/5 scale car to 62+mph successfully....
The video you linked was using a CC/Neu 2200kv motor. The motor is a man compared to the child of a motor you want to use.
N. Rustler conversion
08.08.2010, 03:14 PM
Indeed, the setup here seems a little 'confused' for what the OP wants to acheive. A 1/5 scale onroad, on 6s lipo, that would be a great candidate for the MMM & 2200v motor- a 2800kv motor on 3s is barely suitable for a 1/10-1/8 onroad.
I would suggest a hobbywing 150amp esc, ~1600-1900kv XL motor and 6s for a fast setup, bit cheaper than the MMM and should hold up alright.
ABP
08.11.2010, 08:03 AM
OK i changed my mind... I will make it a baja tipe car...maybe a sandraill tipe car.
So i started on the roll cage.I will be more complex but I need to figure out how I want it to look at the end.I like the black sandraill in the picture I posted.
ID:	9245   Click image for larger version
ID:	9244   Click image for larger version
ABP
08.11.2010, 08:04 AM
ID:	9249   Click image for larger version
ID:	9248   Click image for larger version
ABP
08.14.2010, 05:09 AM
Made a short video of my progres... http://www.youtube.com/watch?v=vxSIrvibbtg
I will use the 1900kv motor and 5s lipo.
thzero
08.14.2010, 08:47 AM
Cool!
Poke around here, there are I think at least two threads about other 5th scale off-road Revo conversions. And I believe on on-road, although he created a complete flat chassis for it (lower center of gravity).
ABP
09.05.2010, 11:57 AM
New pic!
ID:	9312   Click image for larger version
ID:	9313   Click image for larger version
09.05.2010, 12:28 PM
Thats looking pretty cool so far.
Tags
revo 1/5 on road
