Mamba Max & 1512 motor?
nastety92
Mamba Max & 1512 motor? - 11.22.2010, 09:27 AM
I recently purchased a CRT.5 and a 1512 1800kv motor. Would it be ok if I ran the 1512 off of a older Mamba Max and either 2s or 3s power?
The Mamba Max I have does not work and I was thinking of sending it in for repair instead of buying another ESC.
Thanks for the help,
Nick
crusey_aus
11.22.2010, 09:41 AM
Pretty sure if you send them in a Mamba Max for repair they will send you back a Mamba Max Pro
I have the same motor in a Slash 4x4 and chose the MMM and it works well running 3s - 5s
Cheers
11.22.2010, 09:55 AM
Nope they still have MM so I see no reason for Castle to send you a Pro... You can UPGRADE to a pro though for around $75 IIRC.
MM are one of the most robust controllers... They power a CRT.5 without any issues although for 3S it is worth adding an external BEC.
nastety92
11.22.2010, 10:15 AM
Thank you for the quick responces guys. I see the Mamba Pro has a built in BEC, would that be enough for my setup? Do you think the Mamba Pro is a good upgrade to the older Mamba Max?
I have two Mamba Max's, one has a broken on/off switch and the other does not work at all, I think I remember seeing it get a little smokey at one point.
Thanks,
Nick
11.22.2010, 10:59 AM
Most of us remove the swtiches anyway - one less thing to fail
Some people have had issues with the internal BEC on a MMPro with HT servos and have to add an external BEC to avoid the RX losing signal.
nastety92
11.22.2010, 11:19 AM
When removing the on/off switch does the ESC just turn on when you plug the battery in?
Also, which external BEC do you recommend?
Thanks,
Nick
11.22.2010, 11:24 AM
Thanks,
Nick
Yes, the ESC will be ON as soon as you plug the battery in.
There are quite a few external BEC choices, but my favorites are:
- DimensionEngineering ParkBEC: http://www.dimensionengineering.com/SportBEC.htm
- Castle's CCBEC (or pro version, but that's overkill): http://www.castlecreations.com/products/ccbec.html
On a regular MM, I would run an external BEC on anything over 2s lipo. This is because it has a linear BEC and can't deliver much current without overheating with a high differential voltage.
The only reason the MMPro needs an external BEC is because it seems a bit weak. It has a switching BEC just like the external ones, but as Arct1k stated, the MMPro bec tends to have trouble with more powerful/faster servos.
nastety92
11.22.2010, 11:48 AM
Thanks again guys, I think I'm going to get at least one BEC from Castle.
Nick
crusey_aus
11.22.2010, 05:40 PM
Its not just the MMP that struggles with bec issues
My MMM needs one (I use the ccbec) to support an Ace DS1015 Servo
Cheers
