Lets fix the Savage Transmission
JasonB
Flux Fan
Lets fix the Savage Transmission - 02.05.2011, 11:00 PM
The 29T and 32T gears (HPI 86084/86098) inside the tranny tend to granade or quickly wear eachother down to nothing depending on the batch; some are brittle and most are soft.
Both the 44T (HPI 100905) and the 18/23T (HPI 102514) are hardened and don't have this issue. Obviously HPI knows how to make a decent gear, but for some reason, they refuse to fix this problem.
First Attempt: I used GPM Delrin 32T (DSAV1232T) along with the HPI 29T because I figured metal on plastic works great with the pinion/spur, so why not in the tranny. I wanted to use a hard plastic gear, but I have been unable to locate one, so I figured I give delrin a go. My truck has never run so quiet, it was GREAT until . . . after about 10 min, the weak delrin gear broke; $11 down the drain. I really think a 32T gear made out of the same plastic that the 47T spur (HPI 76937) is made out of would be the ultimate fix for this transmission. It would be plenty strong, cheap, and very quiet.
Second Attempt: Some people have had success with the HPI Lightweight Drivegears (HPI 86274/86275). I'm currently running these and my experience is they are even weaker than the stock gears and wear down even quicker because they are so thin. I've got about 15 runs on them and they are already worn down to a point.
Third Attempt: Will be to go back to the stock gears, seal up the bottom half of the tranny with silicone or liquid gasket, and throw in a little synthetic, gear, or silicone oil (just enough to get the bottom of the lower gear wet).
Any other ideas; anyone fixed this thing yet??
02.06.2011, 05:36 AM
Your third attempt idea should do the trick. The wear is caused by metal to metal contact. Oil will stop that. I have some of the stp oil additive that I have planned to run straight out of the bottle in my savage trans. Grease is just a waste of time, flings off at the rpms we turn stuff. Just wish the savvy diff cases were sealed.
JasonB
Flux Fan
Lightbulb 02.06.2011, 10:56 AM
Something I noticed in my Honda 1/1 when changing out the transmission fluid was a magnet at the bottom of the pan. Seems like a good idea in this application because those gears really like to eat each other up and the magnet would help prevent those shavings from getting continuously cycled through all the gears with the oil splash.
02.06.2011, 04:48 PM
Good idea, A small high powered magnet glued into the case somewhere would be great. I have seen those magnets somewhere, I will have to look again.
mjosparky
Sparky
mjosparky's Avatar
02.07.2011, 03:45 PM
See if you can find a small “rare earth magnet”. They are strong and hold their power almost forever.
Sparky
Sharpchuter 245
Dyna Wide Glide
Jahay
02.07.2011, 07:29 AM
15 runs is great out of any savage internal gears to me!!!
i was getting max 5-8 runs out of the light weight gears... which is the same out of the stock cast gears... so i just carried on using stock..
I like the sealed box idea, but i found the best solution which is a centre diff conversion!!! ONLY WAY TO CURE THIS WEAK TRANNY PROBLEM! get rid of it!
JasonB
Flux Fan
02.08.2011, 05:38 PM
I have considered the center diff, but I haven't seen a straight forward way to get it done. Everyone that's done it has had to custom fab a mount. I've been holding out for some company to come out with a drop in solution for the Savage. If the tranny becomes a real pain, I will pursue the center diff for sure.
Other thing is custom length bones; sounds pricey.
Jahay
02.08.2011, 05:43 PM
it sounds pricey.. but imagine the price of a drop in centre diff conversion that will cure all the savage tranny problems? THAT WILL COST A LOT because everyone wants it...
All you need is a centre diff, diff mounts, custom alloy diff plate and maybe one custom dog bone which i paid $20 for... so its not as tough as you may think
ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
02.08.2011, 06:05 PM
With all the Cars and Dog bones made for them. I doubt you need any "Custom" shafts. Just takes a little time and effort to find what will work for you. I mean they make 50-145mm dogbones. Gotta be something you could use...
I agree though CD all the way. It actually makes MT handle somewhat decent...
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
JasonB
Flux Fan
02.09.2011, 12:12 AM
You would think that with all the Savage owners out there someone would have found the part numbers of the existing bones needed to make this happen already and it would be common knowledge.
I'll be first in line for a relatively straight forward approach to a Savage CD.
thzero
02.09.2011, 12:25 AM
Probably because each CD conversion seems to be different.
josh9mille
josh9mille's Avatar
02.08.2011, 07:17 PM
Maybe we should get Monster Mike to make some hardened gears for the tranny that are full width instead of the narrow ones from HPI
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
02.08.2011, 08:48 PM
Could be worth it if the demand is high enough. There are lots of Savage owners out there...
josh9mille
josh9mille's Avatar
02.08.2011, 10:28 PM
It would be better than trying to modify everything to run a CD. Luckily I have had no problems with my HD gears so im not really worried about it.
JasonB
Flux Fan
Cool 02.08.2011, 11:47 PM
I think all we need is a hard plastic 32T gear to run with the stock 29T and it would last for a LONG time and be cheap and easy to replace because it's the top gear. My $3.50 47T plastic spur has lasted for 6 months and is showing no signs of giving in.
Pics of my new tranny. Three magnets that I had in my parts bin. One is under the gear wedged beneath the bearing holder. Just have to wait for the top gear to come in.
ID:	9701Click image for larger version
ID:	9702Click image for larger version
