Lipo charging question
nastety92
Lipo charging question -
02.17.2011, 02:31 PM
I have a new to me set of Reedy 2s 5000mah 35c lipos.
When I go to charge these what amp rating should they be charging at?
Also, what is the difference from charging them at 1.00amp compared to 5.50amps?
Thanks for the help,
Nick
nastety92
Find all posts by nastety92
2
What's_nitro?
Soldermaster Extraordinaire
02.17.2011, 02:36 PM
I can't find anything that says they are fast charge capable, so stick to a 1C charge rate, which would be 5A since it's a 5000mAH pack.
A 1A charge would be 1/5C rate. The only difference is it would take 5 times as long to charge your battery.
Either way triple check that the charger is set for a 2s lipo pack.
What's_nitro?
Find all posts by What's_nitro?
3
nastety92
02.17.2011, 02:45 PM
Thanks for the help, I appreciate it.
I just checked it is set for 2s but I had the option to switch the amp charging rate and I wanted to make sure it was right before I started.
Thanks again,
Nick
nastety92
4
What's_nitro?
02.17.2011, 11:37 PM
No problem man. Enjoy the world of BL/LiPo!
What's_nitro?
Hybrid Mode
Switch to Threaded Mode
