hpi 86376 discontinued - Hinge Pin - Need an alternative.
Jahay
hpi 86376 discontinued - Hinge Pin - Need an alternative. - 02.23.2011, 04:54 PM
Hi Guys.... i have had one query today... and now i have another
I need hpi 86376 but it has been discontinued!!! AND I CANT FIND IT ANYWHERE
SUSPENSION SHAFT 4x50mm
So i desperately need an alternative...
SOMEONE HELP ME PLEASE ARGHHH
thank you
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
02.23.2011, 06:11 PM
Does it need to be exactly 50mm (captured)? Does it have to use E-clips?
I'm sure there is something else out there but it would help to know how much room for change there is in the design.
Jahay
02.23.2011, 06:16 PM
Thanks for chiming in nitro...
Honestly it is only meant to hold a hub in place. I guess nuts and bolts could be used but i have never seen that... usually C Clips are used arent they.
I dont mind if it was a little long by a couple of mm as i could use shims to fill it out???
Thanks
What's_nitro?
02.23.2011, 06:18 PM
In that case... http://www3.towerhobbies.com/cgi-bin...?&I=LXAJTU&P=7 ?
What's_nitro?
02.23.2011, 06:27 PM
You could also use a 4mm tube with a long 3mm screw through it. That would have less play in it than a 4mm screw and should be strong enough.
Jahay
02.23.2011, 06:52 PM
Nice idea.. .but they are a little long at 60mm... but could be cut down i guess... but maybe someone can chime in that has similar length pins on their truck/truggy...
THANKS
What's_nitro?
02.23.2011, 06:53 PM
Yeah I figured there would be plenty of room for a locking nut, maybe cut off the excess.
No problem, I hope you get it figured out!
02.23.2011, 07:25 PM
The shorter cen gst 3mm pin work great. It is the upper arm inner pin, holds the upper arm to the shocktower/bulkhead. I will find you a P/n. I had limited success finding the part you listed, but some UK shops did have it a few weeks ago. Google it.
Jahay
02.23.2011, 08:58 PM
i googled absolutley everywhere with no luck!!! seems out of stock and discontinued...
That cen pin is only 3mm.. .it may cause play in the hub?
02.24.2011, 12:17 AM
The hub end pin is only 3mm, but the bulk end pin is 4mm.
p/n is gs025, and you will use a m4 thread nyloc nut to retain it. Much better than e clips.
http://www.cenracingdirect.com/index...ROD&ProdID=288
The listed specs are 4x56 but the extra length is the threads. I can take a pic for you of this pin installed in the lst hub...
_dV
02.23.2011, 10:02 PM
When I bought my Integy rear hub carriers they came with the pins that I think you are talking about.
http://www3.towerhobbies.com/cgi-bin...?&I=LXWSY0&P=7
In a kinda freak accident I bent one but Integy support were able to send out replacements to me for small fee. So maybe you could get some that way.
Jahay
02.24.2011, 04:55 AM
Great idea dv... maybe ill email integy and see what they say!!!
otherwise linc, i like your idea of using the threaded hinge pin... I HATE THOSE DAMN C CLIPS!!!
Oh FG... i looked everywhere for this product!!! Just unable to find them ;0
FG101C
02.24.2011, 07:44 AM
That's funny, seriously when I posted that link it showed in stock, guess it's a popular item.
In Australia https://www.frontlinehobbies.com.au/...4X50MM%20SAVAG
FG101C
02.24.2011, 02:24 AM
http://www.rcplanet.com/HPI_Racing_S...p/hpi86376.htm
Second link listed when googled the part number. Looks to be in stock, what truck are they for, Savage?
_dV
02.24.2011, 03:23 AM
Page at that link says
"Temporarily Out of Stock
We're sorry but this product is currently unavailable."
