The newer mamba monsters have a kv test program, Im not sure how effective it would be with the abundance of different pole counts and other varying factors. but it may be worth a shot
EDIT: Another option would be to use an EagleTree datalogger with the brushless motor RPM sensor. Briefly bench test the motor going to full throttle momentarily (no load on the motor). Then divide max RPM recorded by the voltage at max RPM and you'll get the kv.
Well considering that I probably want to sell it (will consider other wise if its a 2.5D) I sent it into Neu. They will do it free of charge, I just pay return shipping.
