4600kv CM36 motor finally gave out
crazyjr
crazyjr's Avatar
4600kv CM36 motor finally gave out - 04.06.2011, 02:39 PM
My CM36/4600kv mamba motor finally blew a bearing, Didn't really blow out, but close enough to make me stop using it. The motor is still solid, but needs a pair of bearings. Does anyone know the size of the bearings for the ols CM36 (not rebuildable) motors? I am thinking of just replacing the bearings, 3+years and the motor still runs good. I am also thinking of replacing the motor and esc (MM) with a MMpro and a 1410/3800kv motor. How long is the line for non warranty replacements for the esc? and is there a non warranty charge for a trade to a CM36 for a 1410 yet?
04.06.2011, 03:18 PM
If you're happy with the 4600 motor (kv-wise), what about getting one of the newer 4600 motors (not CM36)?
slimthelineman
slimthelineman's Avatar
04.06.2011, 03:30 PM
+1 my 1406-4600kv was friggin amazing befor it blew out the front bearing. Can't wait for the rebuild kits to come out so I can start running it again.
crazyjr
crazyjr's Avatar
04.06.2011, 07:09 PM
If i go for the upgrade, it'll be the 3800kv motor, for two reasons. 1. its the biggest setup that's ROAR legal (like i really care, but you never know) for modified class. and 2. I always go for lowest kv i can. I believe using the lowest kv motor possible, adds to the efficiency of the setup. I know in drag racing and most other racing, the need for extreme efficiency is not necessary. I aim to race, when i can this year, with nitro's and need the best efficiency i can find. I am already working on a combo that should be good for an hour+ in race conditions, using a lehner basic xl 1200 motor and a quark 80 esc and anywhere from 3s to 5s lipo's depending on gearing and race length
BTW, this is going into a stadium truck. I know, Good luck finding a race, but they're are still a few racing them
nuz69
nuz69's Avatar
04.08.2011, 10:18 AM
I am not convinced that the 2 poles lehner motors have a better efficiency than the 4 poles neu motors for car applications (high and low load, not constant load).
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
crazyjr
crazyjr's Avatar
04.10.2011, 08:51 PM
I'm not too worried about which is better or more efficient, I'm more about the kv of the motor and its effect on efficiency. If i had a Neu/medusa in the same kv range, i might use it
