My bl build
roost
My bl build - 10.26.2011, 12:30 AM
started posting on sc but thought you guys might enjoy seeing it come together
Its a Lehner 2240/7, Ice 200 controller, and rigged up center diff. Just waiting on some parts now
a6m532
10.26.2011, 06:41 AM
That motor look sick
Knez
Knez's Avatar
10.26.2011, 07:59 AM
Looks good!
the motor.
Flux 5B CC 1520
1/16 Rally
My Youtube
Russian:Life and Trust is Lost Only Once!
roost
11.01.2011, 12:06 PM
Thanks!
Decided to order a RCM Center Diff mount. Also Batts and pinion gears on the way
MMMMM Fresh parts
11.01.2011, 12:34 PM
Any reason you chose the ice 200 over the mamba xl? They are the same controller, but the mamba xl has car software and brakes and doesn't need a pistix
roost
11.01.2011, 12:53 PM
According to Lehner this motor pulls 160amps so i thought i would play it safe. Xl is rated at 160A
Also i got this esc for cheap on ebay
roost
11.07.2011, 11:26 AM
Here's how it sits now, should be getting rcm diff mount shortly
tested the system out of the car and everything seems to run smooth, will see how it performs under load
http://www.youtube.com/watch?v=YC8qhLRKRJ0
roost
11.07.2011, 10:53 PM
RC-Monster Mount. Nice piece of work
Need to think of a way to mount a mech brake on it. Going to lock the diff as well
snellemin
2 KiloWatt RACER
snellemin's Avatar
11.08.2011, 11:32 AM
so is that motor going to be wired in Delta or Wye?
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
roost
11.08.2011, 11:56 AM
Delta for now, intill i figure out a way to easily swap between the two. Option for low kv runs will be nice
roost
11.11.2011, 09:41 PM
Got my brake figured.
Also took it for a little test run, Gearing is way too high (waiting on pinions) and i blew the stock diff... time to upgrade
coolhandcountry
coolhandcountry's Avatar
12.23.2011, 02:01 PM
What happened next?
Peace!
Country
Help support the
Rc-Monster
Buy here
roost
12.23.2011, 04:15 PM
sorry havnt got around to updating the project on this site. you can find all the progress at savage-central under "Savage Projects" if you like
