I have this GorillaMaxx G1 tranny with GMaxx drivedog, strobe slipper, RCM iddler and FLM half-case:
The challenge is:
I've seen various threads here and there showing off completed conversions but I haven't found a description detailed enough on how to do it. Hence my thread.
Here's what I have so far:
Input shaft. Can I get the
#5366 and which 18T gear should I use? Or should I buy the
#3992 input shaft with gear already installed (downside is that it requires some
heavy modding to the gear as far as I can see)?
Output shaft. Do I need to change it or am already using the newer
#3969 output shaft?
Anything else? What did I miss?
Thanks in advance.
