Flm Combo bulks or hybrid bulks
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
Flm Combo bulks or hybrid bulks - 05.12.2006, 03:28 PM
I would like to know which diffs will fit either the combo bulks or the hybrid bulks....other than UE diffs.....
  Send a message via MSN to sjcrss
boss 302
05.12.2006, 03:29 PM
ofna and HB diffs work
sjcrss
sjcrss's Avatar
05.12.2006, 03:50 PM
do you know which one for which setup buy chance? be more specific please.....thanks
boss 302
05.12.2006, 03:54 PM
those would fit the hybrids(1/8 scale diffs)
if i was you i would go with hb diffs and bulkless hybrid diffs.
Sneeck
RC-Monster Custom
Sneeck's Avatar
05.12.2006, 04:02 PM
Spyder 8, cause it got the alum housing.
Very smooth diff which will take serious abuse.
  Send a message via MSN to Sneeck
squeeforever
squeeforever's Avatar
05.12.2006, 05:46 PM
Basically, the combos are just for factory replacement gears such as stockers and the hybrids are made for 1/8th scale gears.
I would recommend the Lightning Stadium diffs like Boss recommended. There awesome diffs although Ofna, UE, HB, Kyosho(I think), ect...
sjcrss
sjcrss's Avatar
05.12.2006, 08:09 PM
ok which ofna buggy gears will work...does any one know.....I'm really trying to locate some gears...
sjcrss
sjcrss's Avatar
05.12.2006, 09:36 PM
if I eliminate the diff housings...could I use these in the hybrid bulks... if not which ones do you think will work.....
http://cgi.ebay.com/H7-31-NEW-OFNA-H...QQcmdZViewItem
jocktheglide
06.16.2006, 01:40 AM
they will work only if you replace the diff cups though I know UE provides a longer diff cup than the ofna cups...overall YES the same thing and your probably paying more from UE if you buy them from UE, but you do get the diff cups though thats nice.....I mean I got me a hyper 7 differential compelte for 20 dollars it fit in the FLM hybride bulkless, but the diff cup was a issue....:005:
Bomb-Proof
02.16.2007, 05:49 PM
Sylvester, that is for 2. This I am sure of since the fact that if it were for 1, that would mean that 2 of them was required making the price be $360 for just the diffs....UE is expensive but not that expensive....Also, another reason that wouldnt make any since is because the Ultralight diff kit is only $400 ($400 is the list, the sale price is $325 which makes even less sense...)....You can't go by the picture....
that is for 1 not 2.
$99ea diff = $198
cases $60ea = 120
both diffs = $318 or $299 if you buy as package.
So yea, UE is THAT expensive.
Go with hotbodies, they have far superior spiral cut gears. Dual 7XL on 12 cells each wouldnt break the hotbodies.
MetalMan
MetalMan's Avatar
05.12.2006, 09:42 PM
Those will work.
sjcrss
sjcrss's Avatar
05.12.2006, 09:51 PM
Metal man, on the Ue site does this link to these diffs appear to be for 1 or 2 diffs
http://www.unlimitedengineering.com/...ore/13543.html
squeeforever
05.13.2006, 11:00 AM
That would be for 2.
Sylvester
Sylvester's Avatar
05.13.2006, 02:28 PM
That is for 1 diff. There is only 1 cup, 8-8spyder gears, one pinion gear etc. Im sure its for 1.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
squeeforever
05.13.2006, 06:54 PM
