Anodizing Removal
WheelMan
Do Epic Sh!t
WheelMan's Avatar
Anodizing Removal - 11.20.2012, 01:59 PM
Do any of you guys have much experience doing this?
I have done a fair amount of research on it, and have had some pretty good results...with aluminum.
Titanium seems to be where I'm stumped, and can't find much information on. So:
1) Do titanium R/C parts have the same anodized coating as their aluminum versions?
2) If so, can it be removed? If not, can the part be returned to its original silver color?
Reason I'm asking this is because I have successfully removed the anodizing from quite a few aluminum parts (all different grades of aluminum, from different companies) by soaking them in Greased Lightning cleaner, and then polishing afterwards. But, this process does not work on titanium parts that have been anodized...I tried.
I read somewhere that Alumabrite boat cleaner works for removing the anodizing from titanium, but its $25/bottle, and I don't want to spend that much on something that I'm not 100% sure will work.
I understand titanium can be "colored" simply by heating it to a certain temperature (which is not really anodizing)...but this doesn't show promise for my situation, in trying to resume it back to its original silver color.
I have also seen where titanium can be "anodized" by being dipped into a solution (not sure what it is exactly), and then charged with a certain voltage, to obtain the color desired (higher/lower voltages creating different colors).
Anyways, anyone around here have an knowledge on the subject. My overall goal is just to figure out how to remove anodizing/coloring from a couple titanium skid plates I have.
And obviously I know I could just sand it off, but I don't want to remove metal or alter the finish, so I'm not looking for answers like that please.
Thanks guys!
-Travis
Adults are just kids, with money.
Common sense, is not so common.
11.20.2012, 03:06 PM
I've always used Easy-Off oven cleaner (not the "safe" version, the full-bore burn-your-skin kind) for aluminum, but never tried it for Ti.
bdebde
That's All Folks!
bdebde's Avatar
11.20.2012, 03:53 PM
I have some anodized ti turnbuckles that seem to have the color wearing off... perhaps just a bit of polishing will remove the color?
Blazerss
11.20.2012, 05:49 PM
I have removed the anodizing off of Titanium by simply polishing it with a course compound on a hard wheel. It will take a while on TI skids that have the grain in them, but it will work. TI that was polished before getting anodized is much easier to strip, you just hit it on a polishing wheel and it comes right off. I have also heard that oven cleaner will work, but I have never tried that.
11.20.2012, 10:34 PM
Ti isn't naturally silver, that's polished Ti. Ti is naturally that cool rainbowy color.
If chemicals or polishing doesn't work, you can sand without altering the finish, just use a higher grit of sandpaper, say 1000 grit.
WheelMan
Do Epic Sh!t
WheelMan's Avatar
11.21.2012, 01:03 AM
ok, well it looks like I've got a few different methods here to try out.
Thanks for the insight, guys! I'll let ya know how it all goes.
-Travis
WheelMan
Do Epic Sh!t
WheelMan's Avatar
11.23.2012, 02:59 PM
Well, I got the anodizing off. Although I had to resort to a method, which I knew would work for sure, but just did not want to do. It turned out ok though, so I'm happy.
Greased Lightning = Fail
Easy off oven cleaner = Fail
Drano (w/caustic soda/lye) = Fail
Coke (suggested by a friend as a last resort, haha) = Fail
Final last resort, WIRE WHEEL = Success (as expected), just had to do it with care.
Before:
After:
Front skid wasn't anodized obviously, just needed some polishing.
-Travis
MiRatlhed
RCMTC-MI
MiRatlhed's Avatar
11.23.2012, 03:17 PM
Nice work man! That center skid looks great. I took some Ti skids to a machine shop one time because they had some pretty good scratches in them and I wanted to see if he could mill off a slight amount of material. He ended up using a scotch brite pad and they came out looking like your center skid.
Blazerss
11.25.2012, 01:55 PM
No problem, glad it all worked. I'm going to have to pick up a hacker or 2 for my Emaxx project. I saw that one on Ebay, I just didn't bid, now I wish I had of. Oh well, there will be more.
nastety92
11.28.2012, 03:48 PM
I'm not sure what these cost but if you are looking for another set here is one for sale over on rctech.net
http://www.rctech.net/forum/r-c-item...-t-e-maxx.html
Nick
Tamiya TRF801Xt-e
WheelMan
Do Epic Sh!t
WheelMan's Avatar
11.28.2012, 04:29 PM
Nick
MiRatlhed actually led me to that very same listing shortly after I started this thread but thank you!
I ended up finding some that were in much better shape though, so I passed on this set. Although now that I see they are still available, I might have to get them for my older Maxx, which still has the buttery bendy aluminum skids.
-Travis
Kcaz25
Kcaz25's Avatar
07.27.2013, 12:49 PM
Does anyone know for sure if Alumabrite boat cleaner will work on titanium? Sanding/abrasion is out of the question here.
I read HERE that
Aluma-Brite Aluminum Boat Cleaner is an acidic compound used to remove corrosion and oxides
I think titanium color is an oxidation process.
-Zack
07.27.2013, 11:56 PM
All the things wheelman used above are acidic compounds, and none removed the anodizing from Ti, so I'm gonna say the boat stuff probably won't work.
WheelMan
Do Epic Sh!t
WheelMan's Avatar
07.29.2013, 08:45 AM
All I know is that the caustic soda/lye in the granular drano I've been using is what removes the ano from aluminum.
And that Alumabrite is the only thing that actually works for removing ano from Titanium.
I do not, however, know why. lol
-Travis
SV6000
SV6000's Avatar
08.02.2013, 11:20 PM
Wheelman, how long did you leave the aluminium parts in the draino for. I am going to give it a go but a little worried that the draino will eat the aluminium
CUBIC INCHES = CUBIC HORSEPOWER = CUBIC DOLLARS
