Brushless Losi LST XXL
wellby
wellby's Avatar
Brushless Losi LST XXL - 03.08.2013, 10:10 PM
New project LST XXL with a Summit trans Running a Neu 1521 first on 6s than if all goes well 8s. More pics later after I make more progress.
ID:	10608   Click image for larger version
ID:	10609   Click image for larger version
2 more
wellby
wellby's Avatar
2 more - 03.08.2013, 10:18 PM
A couple more
ID:	10612   Click image for larger version
brainanator
brainanator's Avatar
03.08.2013, 11:48 PM
Nice! Can the summit trans take that kind of abuse?!
wellby
wellby's Avatar
03.08.2013, 11:59 PM
I guess we will see
more updates
wellby
wellby's Avatar
more updates - 03.13.2013, 10:01 PM
Got it running today its a animal on 6s cant wait to try 8s
ID:	10617   Click image for larger version
ID:	10618   Click image for larger version
wellby
wellby's Avatar
03.18.2013, 03:27 PM
Wow over 16,000 views on only one comment you guys are a tough ;)
Well it survived a 8s run no problem. motor and esc stayed cool. Just need to upgrade to a more fitting wheel set for a monster truck.
Kcaz25
Kcaz25's Avatar
03.18.2013, 08:32 PM
Hey that is very cool! Big horsepower. If the trans breaks, and I'm not saying that it will, are you going to install a center diff?
It looks well balanced. Is that a lutach esc?
wellby
wellby's Avatar
03.18.2013, 08:42 PM
Good eye that is lutach 10s 120 amp esc. Had it for a while and never had a problem. I don't think the trans will brake that easy with a properly set slipper and if it does its cheep to fix.
nastety92
03.18.2013, 09:30 PM
Truck looks great. How big is it?
What mph do you have it geared for? On 6s and 8s it must be a Beast.
How about some video?
Nick
Tamiya TRF801Xt-e
WheelMan
Do Epic Sh!t
WheelMan's Avatar
03.19.2013, 11:03 AM
Yes a video would be great!
-Travis
Adults are just kids, with money.
Common sense, is not so common.
wellby
wellby's Avatar
03.19.2013, 09:58 PM
Working on some more oics and videos for you guys. Haven't had a lot of time to run it but seems to be durable. 12Lbs8Oz with a 6S 5000mah batt seems pretty light to me. I like the long wheel base of this truck, makes it stable and less prone to wheelie.
03.20.2013, 07:35 AM
I like how you mounted the esc to the front tower or so it appears..good idea to help cool it. I saw someone else do this w/a truggy and an RX8 who races and he did it as it kept his esc a lot cooler with the constant airflow
wellby
wellby's Avatar
03.20.2013, 02:52 PM
Thanks A lot I have a CPU fan that I mount to the front of the shock tower to help cool the ESC but I haven't needed it yet as it is still cold out
some more
wellby
wellby's Avatar
some more - 03.21.2013, 10:59 PM
Trying the Cen Nemesis wheels and tires on the Losi. Looks like a monster truggy
ID:	10621   Click image for larger version
ID:	10622   Click image for larger version
03.22.2013, 11:54 PM
Is that the 2sd summit trans? Why not swap the internals for the single speed setup from the brushless emaxx. They must be stronger...
On the other hand, my summit rand the wide ratio 2sp trans and a big outrunner. In low it would break mip driveshafts, and in 2nd it could do backflips. The trans never gave me any issues, and I ran the 4 series swamper tires from rc4wd, they weight twice as much as a std mt tire.
Cool setup, must be a beast on 8s. My lst2 on 6s with the 1717 castle motor was crazy fast.
