MT4 G3 / ST1 Pro Bash Truggy conversion
Lizard
Lizard's Avatar
MT4 G3 / ST1 Pro Bash Truggy conversion - 08.12.2013, 07:48 AM
Hi,
wanted to share my not-yet-finished Thundertiger MT4 G3 Bash Truggy Conversion.
Well, generally the MT4 G3 seems to be a decent car, however I did not like a few things: The plastic cage is way too small, it won't allow for larger 6s packs or larger motors. Even if I managed to stuff in 6s there, the center of gravity would probably be too far to the right of the car. Also, the whole chassis is not really stiff. I didn't want to add a "Harley" Top Brace, that's too heavy, too ugly and the center of gravity gets elevated too much.
So I removed the plastic cage completely and changed the layout.
Used some angular plastic and made some chassis enclosures and batterypack holders. For stability, I added the chassis braces from the TT ST-1 Pro. Good thing is, my construction weighs about the same (250gram) as the stock plastic cage. Gives a more rigid car now with better weight distribution but still stock weight.
For motor/ESC I'll be using a Castle 1717 + MMM extreme from an XO-1. To make the 1717 fit the engine holder I had to open up the holes for the engine screws to 4mm and put 2mm Aluminum underneath for chassis clearance.
The center diff is composed of Savage 7075 Nova Diff-Housings, Nitro-Diff-Mod (little blocks on crosspins, like in newer Savage diffs), Savage spider gears, Kyosho 46t steel spur and Kyosho outdrive cups.
For Motor pinion I haven't decided yet, there is enough space to mount something between 17 and 22, so I'll have enough options.
The Body I will be using is from a Savage Flux, it fits pefectly in front of the Spoiler with it's flat truck bed. In addition to the Spoiler I mounted the MT4 G3 wheelybar.
I haven't decided yet on the layout of the front, maybe I'll put the steering servo to the left side, this way I have lots of space on the right side for a receiver box.
CerberusVI
CerberusVI's Avatar
08.12.2013, 11:20 AM
Looks good, I want to see some vids when you get it all done with the 1717 combo in there! I almost jumped on the MT4-G3 band wagon when they 1st came out, but instead i built a Mugen Mbx5t. Still tempting to make it more into a Monster truggy like the G3
Lizard
Lizard's Avatar
08.13.2013, 03:55 AM
hehe, "bandwagen" that describes it well. Couldn't really understand why that MT4 G3 got hyped so much. I mean, it's a nice car, but not indestructible, like everybody says. I only got it because it was cheap and I already have a ST-1 Pro, this way I have a nice truggy for bashing with lots of spare parts.
Well, yesterday I finished the diff top-plate prototype made from acrylic glass. I will redo it later with alloy or carbon fiber.
Also weighed everything, final weight with 6s 5300mAh packs will probably be around 5.4 kg (12lbs). Castle 1717 motor with Savage diff is about 200grams heavier than stock motor.
CerberusVI
CerberusVI's Avatar
08.13.2013, 10:14 PM
Looks good! i took my Mbx5t out with some 40 series road rages with a castle 1515 on 6s geared for around 64. I think that's around the fastest i've run any of my kits. What kinda speeds are you going for in your setup?
I don't want to say im a hater of the Mt4-G3 but i hate seeing all the OMFG its the BEST BASHER EVUR! When in reality it has weaknesses just like any other rc. It's probably a really good kit, the price point for a rtr is good, but in my eyes it's not the end all be all. I have to stay away from RCU and the wonder tiger forums now because of all the favoritism, loyalty and one sided assumptions about other kits.
Anywho...I like how your going outside the box with this build and not the normal brace the chassis, buy a bunch of digi-dem parts, buy better hinge pins, add a summit bumper stuff
Lizard
Lizard's Avatar
08.14.2013, 07:26 AM
I'm not sure yet on the gearing, I hope I can use the 46/22 combo without the motor getting too hot.
46/22 with 6s and 3.7v per cell would calculate to 70mph (without tire balooning factored in).
Lizard
Lizard's Avatar
08.19.2013, 06:42 AM
Well, the car is almost done.
The steering servo posts are the original ones I cut out of the MT4 G3 plastic cage. RC Box is from a Traxxas XO-1.
The ESC is mounted to the chassis plate as on the XO-1, but I'm not really happy with all that plastic, I think I will put everything in some Epoxy later.
Weight with 6s 5300mah battery, Body and HPI Phaltlines is 5303g, with Traxxas XO-1 wheels 4879g.
Gearing is 46/21, with XO-1 wheels and 6s with 3.7V that's 80km/h or 102km/h with Phaltlines.
Did a testrun yesterday, well, what can I say, the wheels take 0.5 seconds to accelerate from zero to 50mph, just the car has problems keeping up with that . Total driftmachine, but drives very well and controllable.
Motor was about 60 degress celsius after 15 minutes, I need to put a fan on it ...
Dr_T
Dr_T's Avatar
10.27.2014, 05:41 PM
Hi Lizard!
I'm thinking of getting those PMT tires for my 8ight-T, to try and get a bit faster than those "baloon assisted" runs I did on the Reely tires. I really like the 120mm OD size, as 140+mm would only increase wheelying and 97mm is too small for my gearing options. Would you recommend them?
Ideally, I would want to try and mount them onto some standard (97mm dia?) truggy wheels to avoid the whole squares thing and to use softer foam inlays. Held a pair today in a LHS and they're really hard. You know if they're sold somehwere as tire only? Have you tried ungluing them for using softer foam inlays?
Lizard
Lizard's Avatar
10.28.2014, 06:27 AM
Not sure if it's possible glueing them to a 1/8 Truggy rim, but I also searched for non-glued 1/5 touring car tires, couldn't find any, only 1/5 rain tires.
Ungluing them is probably not going to be easy, I won't do that anymore, did that years ago with 1/8 tires, tried both the acetone method and oven method, it's a mess and smells like hell.
If you put in softer foams, you'll probably also have to turn down those additional plastic parts of the rims like I did with the larger rims, otherwise bumps will probably "go through" the foams and hit the rim.
Here's what I mean:
On my 5.4Kg Truggy they didn't make much grip and didn't reach operating temperature, I guess the car was too light. Also the foams were a bit too hard like you already noticed. With the 8Kg Twin Truggy they are okay when they reach about 40-50 celsius. From what I've read in largescale forums, they need a 10Kg car and temps of 60-70 Celsius to get real sticky like glue.
Maybe try the new GRP 1/5 tires, they are supposed to be about 10% lighter than the PMTs and GRP claims their rubber compound doesn't rely on temperature. Not sure if that is true though.
Dr_T
Dr_T's Avatar
10.28.2014, 07:21 AM
Thanks! Yeah, might have to go with squares then. The new GRPs are actually under 60 EUR shipped from IT for 2 pair, that's not bad at all.
Being a total noob at this, what compound would you suggest, given the truck is about 5.4 kg like yours, the softest (S1 SuperSoft)? I like them to be grippy, but if that means wearing them out after a couple of runs, I'd settle for a bit less grip and a harder tire.
What compound are your PMTs and how did those wear on your truck? I've seen some softer ones being sold used on eBay and they typically look shredded.
EDIT.
Surface is likely to be that HSV Stadium Parkplatz in my video here, not even asphalt, but it'll do for now :D: https://www.youtube.com/watch?v=oxQXPdnsYAY
Lizard
Lizard's Avatar
10.28.2014, 07:53 AM
I have the softest compound. Wear is okay with that, have run them a few packs on the Twin now and there's still a lot rubber left.
Not sure though how they perform on the surface you want to run them, I think they might be too hard for the surface and not run well. Like toktok-toktok-toktok :)
Dr_T
Dr_T's Avatar
10.28.2014, 10:09 AM
Yeah, surface is not ideal, but at least there is space to practice a bit. I haven't found a nice piece of empty asphalt yet here; for time being, I guess suspension has to stay soft and just work a bit harder.
Thanks for pointing me in the right direction. These 1/5 GT tire size and weight look perfect for trucks and truggies.
