quark problems!
tallyram
tallyram's Avatar
quark problems! - 07.31.2006, 09:47 PM
i'm trying to run 6s lipo and having problems. it coggs really bad on takeoff, but after that it screams! i'm pretty sure everything is wired correctly, not sure though. please help.
  Send a message via AIM to tallyram
cemetery gates
07.31.2006, 09:53 PM
maybe you should try and set the neutral range slection to wide? that should help I think...
MetalMan
MetalMan's Avatar
07.31.2006, 11:22 PM
I've heard of a similar problem using 6s Lipo over at RCZ. It seems like it's just a design flaw that causes the behavior.
tallyram
tallyram's Avatar
08.01.2006, 12:14 AM
i think i'm having the same issue that coolhand is having. i set neutral range to wide, but it still jerks violently. why rate a controller for 6s if it doesn't work? i know 6s is nominal 3.7 and charged at like 4.2, but doesn't everyone run fully charged packs most of the time? i mean come on! quark isn't very impressive to me! they better do something for me!
08.01.2006, 12:39 AM
Just out of curiosity, it that the 80 or the 125?
tallyram
tallyram's Avatar
08.01.2006, 12:42 AM
hey brian, its the 125b.
08.01.2006, 01:01 AM
Hmm. Up until now, I think the only ones reporting this issue were the 80, but I guess it's not limited to those.
tallyram
tallyram's Avatar
08.01.2006, 01:09 AM
nope! check radio control zone, someone has the same problem with the 125b on 6s. he tried 2s, 3s, 5s, and 6s. all worked great except 6s! wish i would have known, guess i'm stuck with it now.
go4gold
mod emaxx
go4gold's Avatar
08.01.2006, 03:05 AM
Monstermike just wrote a good review on the quark
So many toys and so little time
tallyram
tallyram's Avatar
08.01.2006, 06:33 AM
read closely. my setup differs from his.
danverz
08.01.2006, 03:41 AM
Hi,
what motor do you use ?
Did you try other ones ?
You can also try to speak directly with Frank Root. He's a Sky&Technologies
guy: frank@quarkbrushless.com.
Ciao,
Daniele
tallyram
tallyram's Avatar
08.01.2006, 06:36 AM
Originally Posted by danverz
Hi,
Ciao,
Daniele
i run the same motor as you, lmt 1950/8. its not the motor, its a problem with the controller. i'll talk to frank, thanks, tally.
Darren
08.01.2006, 07:32 AM
It might be a high cell count thing. My Quark 125 and 9920 both do it alot on 18 cells, but not really on 14 and a little bit on 16.
MetalMan
MetalMan's Avatar
08.01.2006, 10:40 AM
Frank's response to the other guy on RCZ was that there is no need to run 6s Lipo, and he failed to answer the question about what to do with it.
tallyram
tallyram's Avatar
08.01.2006, 08:52 PM
i read that, but i figure it might help to speed things up on a fix or something if they hear of more problems. frank said to send it in and it would be replaced with a new unit in 3-4 weeks, they are out of stock until then! guess i'll try 5s at the track this weekend, my 2s should be in friday. i'm reading that some people are running 6s with no problems, i can't verify that though. does anyone else know of or read about people running 6s successfully?
