It is possible but it requires a bearing spacer. The maxx large side bearing is a 10x15 vs the revo's 8x16. One of two things has to happen. Either machine out your maxx housings to accept the 16mm bearing or have a 8x10x4 adaptor bushing made to fit the 10x15 bearing on the 8mm side of the diff cup.
Yeah, 15X8 bearings are hard to find. I guess a 8/10mm adaptor is the easiest to make then. But then you would need a lathe, and with that lathe, you could also make the small notches for the o-rings in the cup/ringgear. (thinking while i am typing...) which should work just as well.
