stock lightning diffs question -
08.11.2006, 05:57 AM
Hi guys, I just received a pair of new lightning diffs, and i wondered if it was normal that they are pretty difficult to turn with hands... I imagine that it's due to the oil diff that is cold... Am i right?
Or do I have to open the diff cups to put a lighter diff oil on it?
Can someone help me please?
All thanks,
Fab.
just leave them alone - unless your going to change diff oil for a reason - a little tight is better than a little loose - they will break in - good luck...
ok thanks, my old diffs were completely untightened, cause i run 80% asphalt and pavement... i will see what will be the behaviour of my car...
and yes if it's some silicon oil it can not be affected by temp... that's right Serum, I forgot that fact...
again i will let you know how it runs... i build a new E-maxx actually, from my old one that i shew here 2 weeks ago...
ok i mounted the diffs into the hybrid bulks, but i discovered that i needed to change the lateral cups??? My cvd's are 4 or 5mm too short for the lightning diff cups...
I have the MIP cups that come with the wide shiny cvd's, and i wonder how to make them fit these diffs...
please i need help to finish my car, that's the only thing that make me crasy... i run wide RPM arms and MIP wide cvd... what's wrong with my config??? What diff cups to use on the lightning diffs???
thanks in advance...
Fab.
in that pic my pivotballs are tightened at max... the cups seem to bee too short... where does the length problem come from???? that makes me crasy... 200$ of parts and it doesn't work at the end... :(
i didn't found any idea about how to use my MIP cups on these diffs... Lightning cups don't have any screw...
those are not MIP but they are the same length... pic was taken before i tried to mount the MIP ones...
Serum, you're right, i will try to short my arms about 3/4mm each...
yes you all right, the MIP cvd's are at the right legth... i made a mistake in measuring... shame on me again, it's really hard to enter the race word... :(
