Quick gearing question. I relocated my feigao 6s and mgm over to the new pede i bought. my question would be what could i safely gear that sucker to get the best performance?
Thanks
S^3: everyone wishes they could design modifications like these.
This motor can only be geared according to the quality of your packs. If you have better packs, use a bigger pinion. Otherwise you will get poor performance with high gearing if your packs aren't up to par. Don't worry about heat. Basically it will heat up a certain amount no matter what gearing is used and no more than that until you gear really really high. Peak efficiency happens at above 100 amps.
the novak ss5800,is it as fast as the mamba i know the novak is smooth but do u also need a ubec I would like to take out my novak and replace it with something faster but longer runtime 7 cells
humm, i will give it some consideration. I am not looking for blistering speed ( i have several other trucks for that). I am looking to keep it around 40mph which is where i am now, but may some more torque to keep the big meats moving.
