While I’m showing the components of the truck, I might as well show these too:
HV-Maxx 6.5 (4.5 to come in due time...)
My Hitec Aggressor CRX With Spektrum Add-ons.
After I got my Steel Idlers in everything seemed to come together pretty quickly. Here are pictures of the completed truck. Enjoy!
As you can see, its has a very low stance, which gives it its very low CG. This picture also gives you a perspective of its long wheel base.
A few closeups of the red linkages (some of my favorite parts - they just look awesome).
Well, there they are, I hope you enjoyed them. I’ll try to get a video up soon, but I have to get a cameraman.
Also, for those of you that are probably wondering, the wheel base is 14 and 1/4 inches, the bumper to bumper length is 20 inches, and the bumper to wing length is 22 inches.
Also, here is a list of every single part that went into the truck. There may be a few extra's like spare pinions and spurs for gearing or whatever.
Gorilla Maxx Carbon Fiber G2R Conversion Kit
Gorilla Maxx Black Foam Pads
Novak HV-Maxx 6.5 Brushless Motor System
Novak Capacitor for HV-Maxx (2)
Hitec HSC-5955TG Titanium Gear High Torque Servo (Steering)
Hitec HS-5925MG High Speed Servo (Shifting)
Hitec CRX with Spectra and Novak XXtra Synthesized Receiver
Spektrum Pro DSM System
Spektrum Electric Telemetry
Spektrum Voltage Protector
Traxxas Revo Front and Rear Bulkheads with Braces
Traxxas Revo Front and Rear Bumpers with Mounts
Traxxas Revo Rear Bumper Mount
Traxxas Revo Front and Rear Differential Retainers
Traxxas Revo Rocker Bearings
Traxxas Revo Front and Rear Shock Mounts
Traxxas Revo Steering Bellcrank
Traxxas Revo Axles
Traxxas Revo Axle Carriers
Traxxas Revo Skid Plates
Traxxas Revo Front and Rear Body Mounts
Traxxas Revo Screw Set
Traxxas Revo Differentials
Traxxas Revo Front A-Arms
Traxxas Revo Set Back Rear A-Arms
Traxxas Aluminum Pivot Balls
Traxxas Hard Anodized Teflon Coated GTR Shocks
Traxxas GTR Springs Purple
Traxxas GTR Springs Pink
Traxxas P3 Rocker Arms
Traxxas Red Aluminum Push Rods
Traxxas Aluminum Rocker Posts
Traxxas Tubes Aluminum Toe Links
Traxxas Heavy Duty Servo Saver Spring
Traxxas Aluminum Hollow Balls
Lunsford Titanium Hingepins
Lunsford Titanium Steering Turnbuckle
Pro-Line Aluminum Steering Arm
Traxxas Aluminum Hex Wheel Hubs
Badhorsie Black Shock Socks
Unlimited Engineering Hardened Steel Lightweight Idler Gears
Traxxas Lightweight Input Shaft and Drive Gears
Traxxas Lightweight Idler and Output Shaft
Traxxas 36T 1st Gear Output
Traxxas 31T 2nd Gear Output
Traxxas Drive Dog Output
Traxxas Transmission Case
Traxxas White Lithium Grease
Traxxas Slipper Clutch Tension Spring
Traxxas 6x8x5 Teflon Washers
5x11x4 Polyamide Sealed Bearings
6x12x4 Polyamide Sealed Bearings
Traxxas Anodized Heatsink Motor Mount
Traxxas 3x8 Caphead Screws
Robinson Racing Double Disk Slipper with 66T Spur
Robinson Racing 68T Spur
Robinson Racing 70T Spur
3/16x3/8x1/8 Rubber Sealed Bearing
Wing Tote Deluxe Truck Carrying Bag
Associated 70wt Shock Oil
Traxxas Antenna Tube
Traxxas Body Washers
Dubro Black Antenna Tube
HPI Black Wheel Nuts
HPI M4 Black Lock Nuts
HPI M3 Black Lock Nuts
Pro-Line White 1/8 Scale Wing
TeknoRC Adjustable Wing Mount
Pro-Line Crowd Pleazer LST 2 Body
Traxxas Hurricane 3.8 Rims
Traxxas Response 3.8 Tires
Integy Black Aluminum Antenna Mount
Robinson Racing 13T Pinion Gear
Traxxas 14T Pinion Gear
Traxxas 12T Pinion Gear
Robinson Racing 11T Pinion Gear
Anodizing
