quark or mamba maxx for e-revo -
10.15.2006, 11:37 PM
i read all the posts on how great the mamba max but is it a better choice over the quark monster pro for an e revo on 4s or 6s? i'm planning on getting one of the neu 1515 motors as everyone raves about them... although i'm a big fan of pletty's from my experience with the extrem/mtronics pro combo in touring cars and offroad 1/10 4wd electrics... i've always wanted to get a big maxximum but it seems like everyone has moved the neu motors... why?
i guess i'm really asking two questions quark/mamba, neu/pletty maybe lehnr
10.16.2006, 12:49 AM
Welcome to the forum Abiye, the mamba is only good to 4s, not 6s. People have had sucess with running it with the Neu motor you mentioned. There are others here who can give you more insight on the combos you're looking at, just wanted to say welcome and be patient, they will be on sooner or later
TEAM FUSION
10.16.2006, 11:36 AM
I still am not suggesting everyone use a Mamba even though it's been working well. The Quark is working very well also and is intended for such use.
There's nothing wrong with the Pletty motors... I still think they are the coolest motors. What I like about the Neu is that there are more winds to choose from. And they are more available and priced better than Lehner and Pletty ....for us in the states anyway.
KillaHurtz
10.16.2006, 11:59 AM
I really like my MMax/8XL, but as stated, its only been shown to work upto 4s/14 cells, and that's still running it above spec, so that will void your warranty. Using it as we are is not really for beginners (not suggesting you are, just the caveat.)
The Q125 is the safe bet, and will work upto 5s under warr. There seems to be an issue many are having running the Q125 on 6s, so... thats' a bit of a crap shoot. Else you are looking at another ESC if you really def want to run 6s. Possibly a MGM (seems to have been forgotten)? I don't know for those as I've not used a 4-pole motor or 6s lipos, so someone else may answer that ? better.
10.16.2006, 02:22 PM
A little off-topic, but why would 4s void the warranty on the MMax? The manual specifically offers a cutoff value for 4s. And, 4s has the same voltage as 12 cells (give or take depending on load of course).
KillaHurtz
10.16.2006, 04:25 PM
Actually you might be right about the 4s, but 14 cell is def out w/ warr. What is not clear is if some n00b breaks it (say on 4S) and sends it back for repair saying he was using an XL sized mtor on a MT. They do not limit the ESC to just CC motors, so they have to allow some room for other motors but how far that is IDK.
Its more a warning to other users. Its looks like the MMaxes are starting to get pretty popular for such an app, but I'd hate to see a n00b buy it, abuse it (like not run a ubec) and break it just b/c they saw someone else do it on the internet and not really understand what they are gettnig in to.
10.16.2006, 05:50 PM
4S and 14 cells won't actually void the warranty on the Mamba Max as long as a UBEC is used....By the way, what does an XL motor have to do with anything? The majority, if not all, of the XL motors will draw less amps than the 7700 they offer...
KillaHurtz
10.16.2006, 09:10 PM
Shawn had posted in a CC thread back in early Aug when I was first looking at using a MMax in my ERevo, that the MMax could run 14 cells but you would have to disable the BEC. This was in response to someone that wanted to run 14 on the 4600 IIRC. Shawn had posted that was ok, but that exceeded the specs (rated upto 12) and wouldn't be necc covered. (Actually it was this post and the 7700 specs (~700W on 6 cells => 100A ) that got me thinking it would work..)
If this has changed since that is news to me. Now the ? is, if you did it, blew it up, but didn't tell them, would they know?:032: :P Prolly not..
As far as the XL goes, you're right it doesn't really matter. However I could imagine somebody saying to a company's CS "you know that Mamba ESC you designed to go into 3lb T4's and sedans? Well I hooked it upto a 1500W 540XL motor, put it in a 12lb MT, ran 14+ cells on it, and blew it up. Will you replace it?" I could see that company saying "you exceeded the specs and recc's and it won't be covered." I've heard CC's CS is really great and generally they seem good guys, but I have not had the misfortune to have to test it, so take it for what its worth.
Edit: The original post:
Shawn Palmer
Member
RtsBasic:
It's out of spec, and not warranted, but yes - with the BEC disabled you can run 14cells. Just watch the overall rpm of the motor there (voltage x Kv).
Shawn
10.16.2006, 10:03 PM
But will 4s void the warranty? 4s is the same as 12 cells voltage-wise, and they even have a voltage cutoff for 4s listed in the manual. 14 cells is more like 4.5s. I know it can run 4s, but just curious about the warranty. If so, then I think I'll be using the MM in my 1/8 buggy instead of using the Quark or waiting until just under eternity for the Monster Max. I think as long as the user doesn't go higher than 4s and keeps the amperage at or under 100A, the warranty should hold.
10.16.2006, 10:33 PM
4S WON'T void the warranty if you use a UBEC.
10.16.2006, 10:54 PM
Some time in the future I plan on trying the Mamba Max with 5s A-123 cells from a Dewalt power tool battery pack. The nominal voltage is 16.5v, 0.3v less than 14 cells.
RC-Monster TQ
10.16.2006, 11:11 PM
What would you use for a cell balancer on 5S a123 cells?
Ha Ha
10.16.2006, 11:55 PM
Probably one of the normal LiPo balancers I'm using now (LBA6 or Apache SM-505). From what I've read the A123 cells rarely go out of balance.
RC-Monster TQ
10.17.2006, 12:10 AM
Thanks Metal,
I just found that my man Pete is selling m1 cells in his solderless power tubes. It looks like I will be going back to the good ol days of the SPT's. If these cells don't go out of balance much, I guess I won't worry about balancing them then.
I also see the LiPoDapter+ will charge the M1 cells from a standard NiCad/NiMh charger (up to 10 cells at once).
Ha Ha
10.17.2006, 08:47 AM
if the quark is having broblems with 6s then i'll probably stick with 4s as i'm planning to use two batteries connected in series in the revo so that i can use the same batteries one at a time in my xray fk05 and kyosho zx5... i'm still undecided about the motor though...
