UE supermaxx diff set
celticclown
UE supermaxx diff set - 10.25.2006, 08:32 PM
Will the UE supermaxx 8 spyder diff set fit the G2R? Also does anyone know if the set includes both FRont and rear gearsets for the $300 or is it $300 per complete diff assy?
cemetery gates
10.25.2006, 08:46 PM
as far as i know they will not fit. sorry!
and i think $300 is for 2 diffs..........
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
10.25.2006, 08:49 PM
that is the price for both complete diffs....housings included i believe...
Bl E-REVO
Quark 125b
Castle Creations-Neu 2200kv motor
((2s2p)(4s)
7800mah 7.4v Lipo Pack
E-Revo 1/8 scale Hyper 7 CD
http://www.rc-monster.com/forum/show...1&goto=newpost
  Send a message via MSN to sjcrss
celticclown
10.25.2006, 08:53 PM
so the differential on the maxx is different internally also from the revo or is it only the outer housing thats different?
celticclown
10.25.2006, 08:55 PM
I'm trying to decide on integy aluminium outer housings and steel 6pc gearset with maxximizer diffcups or if I should use something else. The UE 7.5 sets seem to be great and bulletproof. I'd rather spend the extra $60 for the extra strength.
sjcrss
sjcrss's Avatar
10.25.2006, 09:02 PM
if it is only a $60.00 difference..I recomend the UE diffs..well worth the $ spent...
Bl E-REVO
Quark 125b
((2s2p)(4s)
celticclown
10.25.2006, 09:09 PM
yea that's why i want to use the UE diff set but it's $300 wasted if they don't fit
cemetery gates
10.25.2006, 09:23 PM
do you want to put these in a g2r, meaning a revo? then i am 99.999999999% sure they WILL NOT FIT!
bye:027:
celticclown
10.25.2006, 09:41 PM
bye:027:
Ok. yes i wanted to use them in the revo. but since they don't fit without FLM yet to be released bulkless I'll go with the original integy outer housings, 6pc steel gearset, and maxximizer cups
squeeforever
squeeforever's Avatar
10.25.2006, 09:31 PM
They won't fit, but FLM and Mike are designing housings to use 1/8th scale gears. Theres a thread on them in the Revo section I believe...
Serum
Serum's Avatar
10.26.2006, 01:53 AM
YOu can wait for the 1/8th diff conversion from MIke. Whatever you do, don't get the nova revo cups. they are no good, improper engineering.
celticclown
10.26.2006, 08:17 PM
OK so I borrowed my friends maxx diff setup and swapped out the internals into the revo case and it works perfectly. So aside from different external housings the internals work.
squeeforever
10.26.2006, 08:39 PM
The main difference is the fact that the Revo diffs are sealed...
celticclown
10.26.2006, 08:50 PM
the supermax diffs appear to be sealed also. 4 o-rings included in kit.
sjcrss
sjcrss's Avatar
10.26.2006, 09:04 PM
they are sealed.....I run the 8 spyders and never had a problem with them
Bl E-REVO
Quark 125b
((2s2p)(4s)
