Will there be cooling issues
GorillaMaxx360
GorillaMaxx360's Avatar
Smile Will there be cooling issues - 12.21.2006, 07:30 PM
I was just going over my buildup of my next project and i was going through possable problems that could happen and i was wondering if heating of the motor would be one of them. I will be running slipperential, 7xl, quark with one 2 fans, rc monster heatsink for esc, external ubec, 4s lipo a 20t pinion, standard size dish 17mm wheels and crimefighter tires and a 36t spur. Do you think i will have heating issues. if so what can i do to fix this. Also if there should not be heating problems is there anything i can do to help the motor run cooler just to be safe. Also the rc monster heatsink for the motor does this fit the 7xl and will this help with the cooling issues. (if this helps my truck will be using a combonation of graphite, titanium, and a small anount of aluminum like the combo bulks and alu diff cups and thats all that will be aluminum so i think the truck will be slightly lighter than stock but not sure.) Thanks a lot :)
coolhandcountry
coolhandcountry's Avatar
12.21.2006, 08:38 PM
20 tooth pinion with 36 tooth spur. You are geared right hi.
GorillaMaxx360
12.21.2006, 08:49 PM
i think? so but what about heat issues
coolhandcountry
12.21.2006, 10:33 PM
With gearing like that. It will put alot of amp draw on batts and esc.
It will make things heat up pretty good. Why such a hi gearing?
Do you have it locked in first gear?
squeeforever
squeeforever's Avatar
12.21.2006, 10:41 PM
Maybe this helps...:005:
I did a little figuring and with the 7XL, 4S LiPo (3.7v per cell), buggy diffs, and the slipperential geared 20/36, I came out with about 40 mph. That is about right....Isn't the reason your not going with the buggy diffs the fact that you couldn't gear it high enough? Well, I think you can....Not sure, but I'm pretty sure that 20/36 is possible with the slipperential. It should allow enough adjustment...Even then, I think you could manage to get Mike to get you a 22T pinion. I know for a fact that he can get a 24T but you shouldn't need a pinion that big. Anwho, 16/36 should be about right if you don't go with the buggy diffs...
GorillaMaxx360
12.21.2006, 10:58 PM
the reason for the high gearing is because i want to achieve 50ish buy being able to use the slipperntial, 4s lipo, and a 7XL. i was going to run HB diffs but i swiched to maximizer because of the lower ratio (2.8 v.s 3.something for HB diffs) for this lower ratio allows me to achieve my disired speeds without changing from 4s to 5s. Also i wanted to gear it so high (if high means up on pinion) so i could get it to 48 but if i used a 14t pinion per say i would be doing 30ish. So basically i geared up so i could get the most out of the motor with out having to go up on cell count. does this make sense
GorillaMaxx360
12.21.2006, 10:59 PM
any better suggestions? i will settle for in the mid to lower 40s if i can run not so hiigh and give the motor a break.
GorillaMaxx360
12.21.2006, 11:03 PM
squee my question for you will there be heating issues/run pretty hot with my setup and using a 20t pinion because it is so high(the pinion). Or no matter what diffs i go with (hb or maxx standard) the pinion being 20t should not overheat the motor is this what your saying. is it hard on the motor to gear it like i previously said (maximizer diffs, slipperential, 36t spur, and 20t pinion) is this bad for the motor thanks
squeeforever
12.21.2006, 11:07 PM
The setup I suggested...It should get you to about 40-43 mph on 4S w/ the buggy diffs and 20/36 gearing. Personally, I would go for 5S with a 8XL.
GorillaMaxx360
12.21.2006, 11:11 PM
squee will the 20t gear no matter what bog down/overheat my motor with the hb or the maximizer diffs basically is a 20t pinion to much to handle for a 7xl and will it create heating issues. thanks
neweuser
neweuser's Avatar
12.22.2006, 11:05 AM
i would say yes, with the high gearing. But hitting 50 on only 4s is a lot of starin IMO. You would be pulling juice pretty good with the higher gearing. You would be better off going 5s.
GorillaMaxx360
12.22.2006, 11:32 AM
neweuser what is the highest pinion (lower than 20t) that i can get to have safe running temps and not as much strarin on the motor. thanks
neweuser
neweuser's Avatar
12.22.2006, 11:48 AM
With the speed that you are trying to get, you will need to sacrafice some of that to get less strain by gearing down. So in all, you will not get to the 50ish mark. You can drop your pinion size yes, but you'll lose speed. If you go 5s, you won't need to worry about it so much. But even hitting the 50ish mark with 5s is hard to do and have a reliable, efficient system that won't get hot. You could go 8xl with 5s and be pretty close though depending on the gearing.
GorillaMaxx360
12.22.2006, 11:52 AM
i man i will scarifise speed i will accept mid to lower 40s and i will drop the ponion size can i reach this new speed level with a less strained motor also what is the pinion size that gets me about to here(this new disired speed) with not verymuch strain on the motor and cooler/more reliable running also any thoughts about a fan and how i could atach it. thanks
GorillaMaxx360
12.22.2006, 12:03 PM
would it be better(for cooling) if i went with the 7XL 540 and the rc monster heatsink(would also hold on the end of the motor) would this be better cooling than the already built in heatsink in the 540c version.
