Telemetry Question
Shark413
Shark413's Avatar
Telemetry Question - 01.05.2007, 04:47 PM
I just got the Spektrum telemetry module and I am putting it on my brushless Revo. It has one temp probe, and my question is should I monitor the temp of the motor, ESC or battery (I run two batteries so I would only be able to monitor one)? Any comments?
Thanks
01.05.2007, 06:02 PM
Depends.
You could put it on the device that has more history of getting hotter.
Or, you could put it on the most expensive device.
If it were me, I would put it on the ESC since electronic components are more sensitive to heat.
Procharged5.0
Procharged5.0's Avatar
01.05.2007, 06:05 PM
I'LL SECOND THAT. I plan to buy the Eagletree Data/Telemetry system. That alows for multiple temps, multiple RPM's, Current, voltage, etc. etc. more money but does much more.
For now, I say monitor your ESC.
GorillaMaxx360
GorillaMaxx360's Avatar
01.06.2007, 01:32 AM
third the ESC. It is a very important part of the car plus is is the most susceptible to heat issues.
MetalMan
MetalMan's Avatar
01.07.2007, 02:04 PM
I would say the motor. Usually ESCs have a thermal protection feature, but sensorless motors don't.
Procharged5.0
01.07.2007, 10:53 PM
Metalman,
From your experience..............
What are the odds of a sensorless motor "burning up" before the ESC "feels the stress" and heats up itself???
MetalMan
MetalMan's Avatar
01.08.2007, 12:07 AM
I would have no idea. I've never burned up a motor. My guess is that the only way to do that would be to run an ESC with high current capabilities with a motor that is smaller and doesn't require too much current. Then, you could overgear the motor and the ESC might not heat up too much, but the motor would get very hot. So basically, it depends on some factors.
Mike.L
Mike.L's Avatar
01.08.2007, 09:14 AM
i would try and switch it up a little, monitor your esc, and then monitor your motor.
  Send a message via MSN to Mike.L
Procharged5.0
01.08.2007, 10:44 AM
That's where I was coming from. I would start with monitoring the ESC. IMHO.
01.08.2007, 11:52 AM
Does the telemetry system have spots for two temp probes? That would solve your conundrum...
Mike.L
Mike.L's Avatar
01.08.2007, 06:02 PM
wondering........ what else does it monitor?
Sylvester
Sylvester's Avatar
01.08.2007, 06:06 PM
It moniters engine temp , voltage of batts, timer, and lap system if i am correct.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
Mike.L
Mike.L's Avatar
01.08.2007, 06:57 PM
what about fuel scince its made for nitros.
GorillaMaxx360
01.08.2007, 06:59 PM
if you mean how full the tank is then no but you could check the fuel if you have a clear tank but if your in a race this would not be in your best intrest.
Mike.L
Mike.L's Avatar
01.08.2007, 07:09 PM
i thought it wouldn't
