losi 8ight
gixxer
gixxer's Avatar
losi 8ight - 01.13.2007, 04:05 PM
Just saw the other 8ight on here so I figured I should post some pictures of mine too.:027: It will be running a mamba max with a feiago 9xl c motor. The battery will be 5s 6000mah maxamps pack. So far I only ran it on a 5s 4000mah pack twice but the pack was not up to it so it is getting sent back, (thanks Austin):027: and being upgraded to a 6000mah pack. The motor mount was done my mike.
Then I get the battery back I will have to play with the diff oils. Currently there is still grease in the front and rear, 7000wt in the center. Hope you like it.
Name:	maxamps pack 001.jpg
ID:	2205   Click image for larger version
Name:	maxamps pack 002.jpg
ID:	2206   Click image for larger version
Name:	maxamps pack 003.jpg
Name:	maxamps pack 004.jpg
Mike.L
Mike.L's Avatar
01.13.2007, 04:09 PM
looks nice, i always like the eight.
  Send a message via MSN to Mike.L
Sylvester
Sylvester's Avatar
01.13.2007, 05:11 PM
Very nice! I like those rim stickers, as well as the yellow paint scheme!
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
squeeforever
squeeforever's Avatar
Nice! What kinda wing is that? Looks similar to the High Downforce wing made by Proline...
cemetery gates
01.13.2007, 05:17 PM
It is the J Concepts Wing
BTW nice buggy gixxer!
Bye:018:
Serum
Serum's Avatar
01.13.2007, 05:15 PM
Awesome thing!
Who made that motormount? Great work!
I have seen the site; but where to get these wheel stickers?
What maxamps 4000 packs did you have? the new 50C thingies?
squeeforever
Serum, you can get them from http://www.upgrade-rc.com
squeeforever
01.13.2007, 05:27 PM
Thank you!
gixxer
gixxer's Avatar
01.13.2007, 09:49 PM
rcmonster made the mount. You are right the rim stickers are upgrade and the wing is jconcepts. The paint was just a simple two color spray can. I was disappointed in the yellow though. It was suppose to be flouresant. also the battery was the 50c ones.
starscream
RC-Monster TQ
starscream's Avatar
01.13.2007, 10:22 PM
Lookin good gixxer,
Are you using the stock spur gear?
How is the weight distribution like with you motor on the oposite side?
How is the braking with motor brakes only?
Ha Ha
cemetery gates
01.14.2007, 12:17 AM
Why were you displeased with the 4000's? I run 5s 4k's in my truggy with a 9xl and they barely get warm....
Bye:018:
gixxer
gixxer's Avatar
01.14.2007, 12:33 AM
I am running a kyosho 44t spur. The 4000mah packs didn't get hot but the tabs were getting hot enough to melt the shrink on the end, so I dont think they were able to handle the load or maybe a bad solder(not sure wasn't going to open it up because austin said he would exchange it towards a bigger pack).
as for weight with the 4000's the motor side was actually heavier. the brakes are fine with just the motor, that is the same way I ran it on my hyper 8.
starscream
RC-Monster TQ
starscream's Avatar
01.14.2007, 01:14 AM
So does the kyosho 44t spur fit the 8ight center diff then (without mods)?
Ha Ha
gixxer
gixxer's Avatar
01.14.2007, 01:25 AM
It should. I didn't try it but I know glassdoctor was running the kyosho gears on his and he had the stock mount. he has an old write up on his buggy and you should be able to see it in his review.
Serum
Serum's Avatar
01.14.2007, 03:23 AM
That's what i was affraid of.. So they don't do 20-30C continues i guess..
