Tools -
01.29.2007, 10:50 AM
Sorry if I posted this before. Ran across it and it made me laugh.........
Tools used by the Home Mechanic
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly-painted fender you were drying.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the work bench with the speed of light. Also removes fingerprints and hard-earned guitar calluses from fingers in about the time it takes you to say, "Ouch...."
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to further round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub you want the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16" or 1/2" socket you've spent the last 30 minutes searching for.
TWEEZERS: A tool for removing wood splinters and wire wheel wires from your hands.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill bit that snaps off in bolt holes you couldn't use anyway.
TWO-TON ENGINE HOIST: A tool for testing the tensile strength of everything you forgot to disconnect.
CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The home mechanic's own tanning booth. It is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume 75-watt light bulbs at about the same rate that 105-mm Howitzer shells were used during the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading. Also sometimes called a drop light, for obvious reasons.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids and for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts which were last over tightened 15 years ago, and neatly rounds off their heads.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to cut hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts not far from the object you are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Works well on fingers. Especially useful for slicing work clothes, but only while in use.
DAMMIT TOOL: Any handy tool that you grab and throw across the garage into a huge pile of junk while yelling "DAMMIT" at the top of your lungs. It is also the next tool that you will need.
01.29.2007, 11:13 AM
Funny stuff. :005:
RC-Monster jumper
01.29.2007, 11:34 AM
good ones, pro, real good ones!:D
01.29.2007, 05:48 PM
LOL! :D that made my day:)
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
01.29.2007, 05:58 PM
Yes that is how it all goes to
01.29.2007, 05:59 PM
The drillpress definition always cracks me up!
01.29.2007, 11:09 PM
The drop light definition is definately my favorite.
01.30.2007, 01:38 PM
HA! I like the dammit tool, I've done that many a time!
01.30.2007, 01:49 PM
I have several dammit tools.
Sometimes you lose the first one when you throw it! :005:
02.01.2007, 07:35 PM
I like the Dammit tool....it works for me...after i throw it and shout DAMMIT....the tool usually lands on the right tool i need (or at least near it) :)
