Question About the G2r
thndrckn
Question About the G2r - 02.21.2007, 01:50 AM
I was reading the following article..
http://www.rcdriver.com/articles/revo_reborn.shtml
and after looking at the pictures, I was wondering is the tranny on that truck backwards? cause thats not how i installed mine...
BP-Revo
BMW M Power!
BP-Revo's Avatar
02.21.2007, 02:04 AM
Well, it is backwards compared to a stock E-Maxx, but thats currently how my Tranny is installed...the weight distribution is better that way.
squeeforever
squeeforever's Avatar
02.21.2007, 02:38 AM
It doesn't matter really...
neweuser
neweuser's Avatar
02.21.2007, 01:58 PM
that is a pretty nice article. I wonder why he used the 8L though? And, he spelled Maxamps wrong a few times. Other than that, very nice work he did! As far as your tranny, mount it the way it works best for you.
BP-Revo
BMW M Power!
BP-Revo's Avatar
02.21.2007, 07:31 PM
The article is actually pretty old. I'm sure it has a Neu or something now.
02.21.2007, 05:48 PM
The tranny is mounted that way because of the direction it rotates the gears- on the emaxx it faces to the rear because of how the diffs rotate; if you use the gorillamaxx motor mount the motor faces the other way, so you have to flip the diffs in order for the truck to go forwards, or if using a sensorless motor you can run it in reverse. The same thing happens in a revo ( the diffs are designed to rotate in a certain direction in relation to the engine), though here you just turn the tranny around- have a play and see what works best for you in terms of weight distribution (as mentioned above). I had to have my emaxx tranny facing 'the wrongway' when I had it in my TXT-1.
