Brushless Setups? -
03.02.2007, 10:33 PM
Can someone recommend a good brushless setup that would work with dual 7.4v 8000 mah MaxAmps Lipo's for under $300? this is going in an E-Maxx btw. Thanks for helping the noob. lol I am looking for something that has a little more power than your average nitro. thanks again I just don't wanna blow $300+ on a brushless system that is over taxed in my E-MaXX, or just plain isn't compatible.
03.02.2007, 10:46 PM
The cheapest is probably going to be a Mamba Max ESC and a BK Wanderer 8XL. You'll need a UBEC too.
However, you're probably going to have heat problems with that ESC unless you use a fan. If that's not an option, then maybe a BK Warrior 9920 with a lipo cutoff. Still need the UBEC too.
EDIT: Oh, and welcome to the forums!
03.03.2007, 03:30 AM
Welcome to the forum Fuzion!
You came to the right place for advice IMO.. read all the positive feedback about the customers of Mike. spending money is one thing, but getting the result you want with your purchase is another bag..
for your 300 dollar budget;
If you want a blast, get a 7XL, runtimes will suffer though.
if you want very decent speed get an 8XL. if you want something that blows away the stock titans, with a very decent runtime; get the 9XL.
With the 8XL/9XL you can set with a MM controller. Good thing is it has got an LVC build in. i would use a 25X25mm fan on the MM to prevent overheating.
Remember; investing money in a setup is going hand in hand with future upgrade of your drivetrain; it is meant for two fair weak motors, and even with this stock setup, the drivetrain gives from time to time.
With both the 9920 or the MM controller, you need an external BEC.
03.07.2007, 08:50 PM
First of All, Thanks for all the Help, you guys are great, just what I needed.
But I did some more research and I realized that for the Kind of Power I need(ok want LOL) i would have to expand my budget. how about this setup?
Motor - Nemisis Blue XLT-1
BK Warrior Speed Control (not sure what model but it costs $230)
Tanic Packs 4S 3700 Lipo
Would it work well and provide nitro beating power? and can someone reccomend a good BEC?
thanks again guys, your all great
03.07.2007, 08:55 PM
Welcome to the forums Fuzion!
I recommend the Mamba Max esc with the Feigao 8XL (C-Series) for the best blend of performance & price.
I strongly recommend that you buy from Mike here at RC Monster. He will treat you right, I can tell you that from recent experience.
03.08.2007, 02:28 AM
That's a fine-design setup. Do a search for finedesign and deside for yourself if you want to buy from him or not. His first contact seems great, but if you have got a problem afterwards, you are on your own.
Here, browse around thru this store;
www.rc-monster.com
What kind of speed are you looking for?
TEAM FUSION
03.08.2007, 02:55 AM
I will second that... stay away from finedesign. Trust us... you can do so much better with a little help form the forum here.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
03.08.2007, 06:38 PM
Welcome, everything you need is here with extra customer service which comes in handy from time to time. +2 on the FD package. You never know what you are going to get from them. Do a search here on the forums and you'll see why.
Go with the 8xl/MM esc with the ultimate ubec Mike sells. It's a win win for sure. It will definately take care of the nitros for you.
03.12.2007, 05:12 PM
the mamba max can handle 4S lipo? I don't mean to sound doubtful or ungrateful but I really wasn't expecting a 1/10 single motor single battery to handle a feigao (sp?) 8X1 and 14.8 volts.
03.12.2007, 05:22 PM
Yes, but you have to disable the internal BEC and use a Rx battery pack or UBEC. There are many folks on here who have run the MM with an 8XL on 4S.
03.12.2007, 07:44 PM
Thanks. would this setup give me power similar to the FD setup listed above?
That is the kind of power I want. and how do I disable the bec?
03.12.2007, 11:34 PM
On the 4S lipo and MM yes, I have run a 7XL on 5s through a MM, and while i don't tell people to do it, it did survive
03.12.2007, 11:52 PM
I have been doing the same thing with a 9xl motor. I am going to go back to 4s though because I think the 5s might be a little to much for the mm.
I will probably end up going back to the higher voltage when the mmm or quark plasma come out.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
03.24.2007, 09:31 PM
would the lehner I picked be good enough to compete with the fine designs motor? thanks and very helpful sticky
TEAM FUSION
Believe it or not, the MM does better on 4s lipo and big motor in my 1/8 buggy than it does on 2s with a 7700 in a 1/10 4wd.
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
