the Controler iss a Hacker Master 90 Acro Comp !
usualy it is RC Aeroplan Controler, with a lot of compftable Features to program with a Prog. box !
it works pretty good, no Problems with starting slow or fast !
I don´t know, maybe the Breake might work also , it is prop. controlable but the Hacker Guys kant give me a garantie if the breakelektric will work in the Car conditions without getting damaged , so I decited to use the mechanik Break System first !
I think I will try to break just with the Controler, because i can losse some weight if this works ! And I´m a low Weight fan !!!
Thanks. Keep us posted on the controller performance. Especially with the braking. It may be another nice alternative for higher power brushless motors.
Also. What is the model of your transmitter and does it program well to the speed control. Danke ...
oh jes, the Transmitter is a very importend when you use a Flight Contoler !
Becaus the Flight contorlers usualy need a Signal from -100 % up to + 100 % Way on the Gas ! If you dont have a Transmitter were you can prog. or adjust this way you might get a Problem ! I use a FUTABA 3PK and this works pretty good !
Before I had a older Futaba Transmitter and there I modified the Gas way on a mechanikal side in the Transmitter to use all, even the cheap Flight controlers !
Some flight Controlers dont need this Signal, they "learn" the Way from Break to full throttle when you start them !
i know some guys working on a very good and not to expencive High Voltage Controler with this features :-) !
