ĄGo Baby Go!
Will This Setup Work? -
06.02.2005, 01:58 PM
HI everyone. I recently have run into an opportunity to acquire a pretty sweet car. I was wonder whether or not the MGM 80 controller could handle a Feigao 9L on 12 cells (2400 sayno). Otherwise what would you reccomend for good runtime and speeds at least into the lower 30's ? I would like to run this controller, because I don't have the money to buy both the controller and the car..... here's a picture
Yes, clean up that druel. :L:
RC18T FT - Quark Castle Creations Airtronics IB
06.02.2005, 02:32 PM
well, the feigao has a current rating of 68 amps, and the mgm 80 can handle 80 amps... Providing you run no more than 12 cells, the mgm compro 80 should be fine
"Out of spec" enthusiast
06.02.2005, 08:03 PM
You have a lehner basic 4200 correct? Put that in and see how it runs. (It wouldn't hurt to try) I think you'll be amazed.
Site Owner
06.02.2005, 11:29 PM
CF truggy. Nice!
Site Owner
06.02.2005, 11:31 PM
The 80 amp MGM will be pushed pretty hard with a 9L. Run a fan and keep your fingers crossed.
ĄGo Baby Go!
06.03.2005, 10:09 AM
I haven't made any purchases yet... Although I am thinking that It would need a new motor and controller, but after recently purchasing the lehner 4200 and MGM 80 its kind of dissapointing to turn around and buy a 9918 and Lehner 3100 XL... Wish they had some slightly used return haha.
Its a lot of money, so I'm looking at all my options. The xxx-t is giving me some minor problems, so maybe this is the break i need.
06.03.2005, 11:21 AM
Hey Re Mix... where are you MN? I'm in princeton. I just got my bl yesterday. I have the 9918/9L.
Hit it hard and watch for parts!
06.03.2005, 11:48 AM
The xl3100 or the 9L are too hot for this more of a direct drive.
I have seen this project, someone worked on it very long,
Try to figure out what gearin it has in the diffs.. (43/13 43/10 or what so ever) And what is the diameter of those tires and what spur/pinion are you planning on using?
I personally think it would be nice to run this setup with a 7XL motor on 12 cells. It would be rater easy on the controller and due to it's 50% larger magnet in comparison to the L size it will throw out a nice torque as well. But i like them being powerfull.. depending on your gearing/size of the wheels a 10L would do fine as well. (the feigao/wanderer L serie has got more torque than the lehner basic XL series..)
Site Owner
06.03.2005, 10:11 PM
I worked with Andy a little on the gearing with this truggy. The 9L with a 13 tooth pinion and the 1/8 tires calculates into high 30s top speed with 12 cells. The MGM could probably handle it.
ĄGo Baby Go!
06.03.2005, 11:21 PM
Really? I heard thet 9L was a little too hot for this car. So I'm thinking a 10L maybe. That would be easier on the MGM hopefully. I do have a fan to run, but I'd rather be on the safe side of things.
Site Owner
06.04.2005, 08:14 AM
The 10L will work quite well also, but Andy and I worked out the gearing on a 9L. The 10L would be easier on the controller for sure. The 10L and a fan should keep you pretty safe.
ĄGo Baby Go!
06.04.2005, 12:13 PM
Would a Hyper 7 TQ conversion be a lot easier on the motor then this chunk of metal? Im looking at my options, and while price is a factor, I'm willing to spree on the car and motor, but I already own a nice controller, so that'd be great.
Site Owner
06.04.2005, 12:18 PM
That "chunk of metal" isn't all that heavy as I recall. I would guess the Hyper 7 conversion to be just about the same load.
06.04.2005, 12:20 PM
You mean Andy from Germany?
Site Owner
06.04.2005, 12:22 PM
No, Andy from Cold Fusion racing (creator of the CFR truggy).
