I have an 18120 and instead of frying something I'd like to ensure that my wiring configuration is correct.
I run two battery packs (total of 14 cells-until I record enough data and figure out which LiPo is right for me). They need to supply serialized voltage (16.8v) to the speed control (18120). The 18120 has four power leads (two red, two black).
The four power leads come soldered red to red and black to black, from the factory. I can assume (I really hate assuming when it comes to electricity) that I just need to serialize the battery pack wiring and that all leads inside the controller terminate properly to support that config.
I sent the folks at BK an image from Run Runners (also found elsewhere) to indicate which battery wiring config I believe should be used. They responded w/ yes, that's the proper wiring.
Here's the pic ->
http://www.rumrunnerhobbies.com/imag...packconfig.jpg
I'm basically going to leave the battery packs alone, no wiring changes necessary. I'll hook up male Deans to each soldered pair of power leads to the speed control, and finally serialize my batteries by using a heavy guage wire to connect the negative lead from one battery to the positive lead on the other battery (using the spare lead on each of the aforementioned mail Deans connector).
Before I blow a battery or fuse stuff together, would somebody mind giving me a sanity check? I'd like to wire my battery packs like the serial connection shown in the aforementiond link. Any clarification is appreciated. BK basically gave me a nod, but I'd prefer a diagram.
thx!
