HV-Maxx 4.5 or MM and 9xl?
E-Maxx King
HV-Maxx 4.5 or MM and 9xl? - 05.26.2007, 12:17 AM
Cant decide what setup? I want somthing that has more runtime and power the the titans. I have 7 cell IB4200 WCE batteries and it makes my truck do about 35 m.p.h. So Im staying with the 2 speed, and something that I wont snap my axles. I not sure If I should go to BL. O and also will I be able to program the esc? Like the threw the USB?
What would I need for this? Im going to get >>
List
3.3 revo axles and centers
3.3 revo knuckles
3.3 t-maxx 3.3 turnbuckles
I need to get
FLM diff cups (x2) $60
Integy Aluminum diff case (x2) $50
Hardened steel idler gear-Emaxx transmission $28
Integy Gear Box Collar (x2) $10
$148 ouch! plus the motor!
Serum
Serum's Avatar
05.26.2007, 02:26 AM
I would take a mm and a 9XL over the novak any time a day..
Without a single doubt; it's a cheaper setup, which delivers more power. You can program it by computer;
you need a separate UBEC though.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
05.26.2007, 10:23 AM
I definately Agree.. that Mamba Maxx ESC is the best bang for the buck! no doubt.!
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
E-Maxx King
05.26.2007, 05:52 PM
Well Lets say If something would happen to it like it fries what do I do then? Do I just put the 3mm connectors back on a exchange it? So What gearing should I be using for this setup? On 14 cells. Does any one have videos of this setup with 12 or 14 cells? Or just pics? Also what about runtime?
Im going to the 3.3 axles so what do I need?
3.3 revo/t-maxx knuckles
3.3 t-maxx turnbuckles
On the revo center one side has like two screws sticking out of it. DO I have to cut those off?
05.26.2007, 06:11 PM
I take it you mean the centre sliders- I would get some proper metal CVDs- much much stronger. The rest of your list is fine.
The MM wont take 14 cells very well.
Specs
Cells 6-12 NiCad/NiMH 2-3s LiPo
Continuous 100 amps
Resistance 0.0003 ohms
Brake Proportional
Reversible Yes - with lockout
Low Voltage Cut-off Programmable
Size
ESC overall: 1.9 x 1.3 x 1.2"
Motor: 1.4" dia. x 1.7"
Weight
(w/wires) ESC: 2.5 oz (70.9 g)
Motor 7.0 oz (198.4g)
Connector Type Universal
I would run the 8xl on the MM with 12 cells. Gearing wise...... start at something like 25:1 overall, then maybe go up on the pinion a tooth at a time/ down on the spur a couple teeth until you find the 'sweet spot' for that setup.
jollyjumper
RC-Monster jumper
jollyjumper's Avatar
05.27.2007, 05:29 AM
way off.
remember that's its not a high rpm motor, you can start gearing a 8XL around 16/1, it'll do about 30ish then.
losi 8ight-t
xray xt8
Finnster
KillaHurtz
Finnster's Avatar
05.27.2007, 07:03 PM
Originally Posted by jollyjumper
way off.
Yeah I do my 8XL/MM right around 16:1
Great amt of TQ and speed on 4S. I consistently radared ~41 mph on 14 GP3300s. Great combo IMO.
E-Maxx King
05.26.2007, 06:42 PM
Well with a ubec. Well I only have $80 for the axles so what? Will thede axles hold the stock titans on 14 cells? In tell I buy the BL? How long will the axles last on the titans?
05.27.2007, 07:28 PM
Wowzers, didnt realise you could gear them that high, its a big leap from the HvMaxx gearing of 25:1 on 4400kv, guess I have to start learning all my ratios again if I went the XL type motor route.
$137 for the MM + $80 for an 8XL + $34 for XL clamp + a few more $ for pinons and gold plugs etc.... = ~$280ish/£140. I'd call that a bargain for what you're getting- I think I have found my ideal setup... now to finish saving up £££ (donations welcome).
Patrick
Patrick's Avatar
05.29.2007, 06:16 AM
My neu 1515 2.5D (1700kv) seems to work well in my e-maxx on 14 cells geared 12.5:1 :018: After a race the motor was 36 degrees C (97 F):027:
I have only used it like this a couple of times so far and I didn't expect it to work so well. Still has good accleleration, low motor temps, lower esc temps than with 7xl geared for about the same speed (high 30's), and runtimes seem as good if not better.
But I didn't buy this motor to use in this setup, it could end up staying though.
05.27.2007, 08:53 PM
Well, the HV being rated for 4400kv is pretty hot. So, you'd need to gear that down appropriately. Plus, an XL motor has more surface area and bigger section for windings, so it's probably more like an L motor. The rules haven't changed really.
coolhandcountry
coolhandcountry's Avatar
05.27.2007, 10:05 PM
I would shot for stock gearing and go from there. 18:1 is stock and the
motor turns more rpm than stock. Bingo faster and more power with same gearing. :D
Peace!
Country
Help support the
Rc-Monster
Buy here
E-Maxx King
05.27.2007, 11:08 PM
Is that with the 9xl? What runtimes could I get? 4200 7 cells. Cause I get about 30-40 on the stock setup.(I not going full throttle the whole time)
E-Maxx King
05.28.2007, 02:16 PM
I just read some stories from bp-revo and someomne else. One said his 4.5 beat a 8xl and mm and the other he kept up with a 7xl. I like the 4.5 or 6.5 cause I drive ay low speeds so there wont be any cogging. And another is cause Ill have a warranty on it I think.
Serum
Serum's Avatar
05.28.2007, 02:25 PM
an 8XL will simple have more torque/power. perhaps he had better grip with his tires or his truck was lighter.. or the 8XL user had poor batteries.
