will this work in a e revo? -
09.09.2007, 11:03 PM
hey guys im building my first electric so i need to know if this will work. it gona be a e-revo (with a e-maxx tranny) i us for bashing and on a track after i build one. so i was thinking of using 2 8s a123 2300 mah 26.4 volt packs wired in parallel with a MGM Compro 160 amp, 24 cell brushless car controller http://www.rc-monster.com/proddetail...MM160243sHCS01 and Neu 1515 2.5d/F Sensorless Brushless Motor http://www.rc-monster.com/proddetail...5_2.5dF&cat=20 .
i was also wondering if i need extra cooling for the motor? something like this http://www.rc-monster.com/proddetail...d=RCM01&cat=20 and if i do what size will fit on that motor? i also have no idea what kind of wire conections to us so i was just gona us the Dean's Ultra Plugs and wires in the battery section of rc-monsters store. well thnx for your time and ansers
Soldermaster Extraordinaire
09.09.2007, 11:18 PM
Well I can tell you that's gonna be one powerful setup!
I really like 5.5mm bullet connectors for high power stuff. If you're gonna use Deans connectors, I'd use a complete set on each individual wire. I would also recommend using 10 AWG wire or larger.
09.10.2007, 12:13 AM
I'm also doing a Revo BL mod and need some help! Not sure what type of gear to buy I'm going to use a 12L Feigao motor with a BK 9920 esc. What type of gear do I use on the motor 5mm bore 32 pitch pinion gears? or 5mm bore, mod1 pinion? What is the difference and why do they have so many?
What size ( # of tooth) would be best suitable for a Revo? I was planning to use the stock tranny that comes with the Revo or a Emaxx tranny if I can get a hold of one.
09.10.2007, 01:39 AM
Revo uses a mod 1 spur gear, so you will need a mod 1 pinion. Pinion size will depend on what batterys you will use. A 12l feigao has a kv of 2048, so 4s lipo or 14 cells would be a decent setup. Using the stock tranny and std tranny gearing, I would suggest and 18 tooth pinion. Then you could vary the spur gear as traxxas makes a 36, 38, and 40 tooth spur. The 18/36 gearing with stock tires will give you about 40 mph. Here is a copy of the speed calc with the numbers I used to find this. I used 4s lipo as the battery, but it is very close to 14 nimh cells voltage-wise.
Differential Ratio: 2.8461538461538462
Transmission Ratio: 2.2941176470588233
Other Ratio: 1
Spur Tooth Count: 36
Pinion Tooth Count: 18
Total Voltage: 14.8
Motor KV: 2048
Tire Diameter (inches): 5.75
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.0172
Spur/Pinion Ratio: 2 : 1
Total Ratio: 13.05882 : 1
Tire Circumference (inches): 18.06 inches (458.83mm)
Total Motor Speed: 30310.4 RPM
Vehicle Speed: 39.7 MPH (63.78km/h)
Effective Speed Rate: 2.68mph/V (4.31kmh/V)
Effective KV Value: 2048
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
09.10.2007, 09:40 AM
Thanks for all the help on this lincpimp. Where do we use the 32 pitch pinions? on Emaxx Trannys?
Other Ratio: 1
Total Voltage: 14.8
Motor KV: 2048
RC Wanna BE
09.27.2007, 09:02 PM
I know this is a little late but I spoke with Mike on the phone about this exact question. I have the Emaxx tranny with a 1950 1800kv. I bought a RR Slipper kit for a RC10 MGT. Then I bought the Ofna spur gear from RC Monster store with a 18 or 20 tooth mod1 pinion. The slipper kit slides right on to the tranny. I modified the Ofna spur gear to hold the rotor plate. Little filing. Everything fit great. If you buy smaller pinions the metal spur gear sent with the kit would work. But thats a whole new thread. Lots of opinons about using a metal spur gear vs a plastic spur gear.
09.11.2007, 03:49 AM
grenade6,
Have you ever seen an A123 cell? I'm just asking because those things are huge and heavy. They are about the size of an alkaline C cell battery and weigh 70 grams each. You're talking about 2.5 pounds of one brick (literally) of a battery pack.
Anyway, if you are going to run that many cells in a truck, I'd shoot for a lower kv motor. Perhaps something in the 1100 to 1200 kv range. I run a 1515/2.5d in my 8ight T on 18.5v and it'll do 50 mph. I think that running the 2.5d on that much voltage for any sort of extended running might result in lots of heat.
I'd go one of two ways. Either the 1515/2.5d on a 5S2P A123 setup, or your chosen voltage with either a 1515/2y or 3d.
09.11.2007, 03:58 AM
lol ya iv never seen one and the last electric i used was from radioshack and it cost me like 100$ when i was 12 lol. the bad news is that i bought the batteries this morning (off the net) so i cant really change my mind now but i havent got the motor yet so ill take a look at those motors. nad thnx for the info even tho i now know i bought bricks
09.25.2007, 11:35 AM
Welcome to the forum kenkamm! That sounds like a nice setup, and the inrunner motor debate is still on-going so any thoughts/numbers/temps etc you have would be useful in determining what works well in any given setup. Got any pics/link?
09.27.2007, 06:30 PM
Z-Pinch racer
09.27.2007, 06:39 PM
kenkamm, that is one nice Revo man!
What motor is that you are using? kv?
I am assuming that is an A123 pack? Is it 4s2p, or 8s?
09.27.2007, 07:11 PM
That is the Align 600XL motor. Kv is 1650. The ESC is the Align 75A model. 8S1P A123s. Part of the reason for using that stuff is cost. The motor and ESC are available for 50-60 bucks each on the used market and 10 A123 cells can be pulled from a Dewalt pack from eBay for $100 or so. Some of the other parts are things I had laying around, like the Rx battery (to be replaced with a 2S Lipo.) I thought some heli stuff would work well to produce lots of power in a land vehicle, and so far it seems to work well. The ESC is an aircraft model, thus has some shortcomings, but still seems to work quite well. It does jerk a little bit from a dead stop, but once moving I can slow down to a crawl quite nicely. I never have any cogging problems.
09.28.2007, 11:44 AM
That is a very nice set up kenkamm. Not that suprised the esc & motor run a bit hot in grass, but for the price its a very very good setup. Also very clean and well laid out- the esc looks like a Bk warrior, only much smaller and neater = cool.
09.29.2007, 05:49 PM
Hi Folks,
Here is some video of my E-Revo with the Align brushless hardware. After making the video I realized it doesn't showcase the power all that well because the resolution of the video isn't all that great and the road rage tires don't grip that well on the grassy hill, and the steepness of the hill isn't obvious on the video. Also since I had to film it while my fiance drove, it was a bit tough since she has a total of 10 minutes of R/C driving experience. Still, I tried to show how the truck can crawl along pretty well and then smoke all four tires at will, even on pavement.
I just wish there wasn't so much gear noise. The whirring from the Align motor sounds pretty cool though. I just swapped in a Neu 1515/2.5D and the gear noise is even more evident. It doesn't seem to have that much more power than it did with the align motor, but I need to experiment with the gearing a bit more. But it's a testament to the Align motor. They are powerful and inexpensive, especially on the used market.
Next I plan to build a E-Maxx and put the Align motor in that and keep the Neu in the Revo.
Man, this thing is fun.
Video:
Please right click and do a Save-As
