Ryobi now offering Lithium batteries
JThiessen
JThiessen's Avatar
Ryobi now offering Lithium batteries - 09.30.2007, 08:19 PM
Ryobi, one of the "low cost leaders" in tools, is now offering lithium 2.4Ah (18V) battery systems. On Ryobi's web site, a battery and charger have a list price of $99 USD. Looks to be a cheaper competitor to Dewalt batteries for the A123 style packs. I'm looking around for who their supplier is. So far, I've found that they are owned by Techtronic Industries Co..
09.30.2007, 08:24 PM
I think you should pick up a pack and do some exploratory surgery. Or, better yet, just wait until someone at rcgroups does it...
JThiessen
JThiessen's Avatar
10.01.2007, 11:08 AM
I would, but I'm like a bull in a china store when it comes to soldering electronics! I can weld almost anything, but for some reason when it comes to electrical stuff, I fall flat on my face.
Serum
but 18V is halve the power of 36V; that 99 bucks, is that for a charger AND the battery?
Its for (1) battery and (1) charger. So hopefully, just the batteries will be quite a bit cheaper. I doubt if they will have A123 quality, but until they are tried, one never knows.
I do see one potential problem for Ryobi in this venture. They are making the new batteries backwards compatible with the old Nimh/Nicd tools, meaning the new Li packs will plug into your existing tools. Which also means the batteries will also fit their old chargers - which arent intended for Li charging......
10.01.2007, 11:17 AM
lol, I guess that would be a problem. Not too many people weld their batteries.
They probably incorporate a circuit in the pack that simply cuts the charge at the end of the CC phase eliminating the CV phase. Similar to how the lipodapter works.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
09.30.2007, 10:27 PM
I'm planning to pick up a pack... I have a Ryobi 18v set, so I have a good excuse. Then of course I will have to take it apart and get to the goodies.
I would like to build a truck that uses the pack just like it comes... just pop it into the truck like you would a drill. Then use the Ryobi charger too. :)
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
09.30.2007, 10:54 PM
The only issue with using the packs "as-is" is that the form factor generally isn't optimized for our use. Plus, the connections aren't as robust as we would like since we tend to draw more burst current than most powertools.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
10.01.2007, 12:07 AM
Dont the batteries (as is) have over-current protection as well?
Serum
Serum's Avatar
10.01.2007, 01:50 AM
Serum
Serum's Avatar
10.01.2007, 11:23 AM
most of them are spot welded actually.
10.01.2007, 12:07 PM
I guess I should have said "end-users"...
Serum
Serum's Avatar
10.01.2007, 12:20 PM
i was playin Brain..
You are one of the people i know sure of they know how batteries are connected..
10.01.2007, 12:22 PM
I know.
I just wanted to clarify for others' benefit.
And the name is Brian.
kulangflow
Never Fast Enough
kulangflow's Avatar
10.01.2007, 03:21 PM
Man, I get that all the time too. In 3rd grade my teacher even put Brain Roberts on my report card.
He claimed it was because I had done so well.
Serum
Serum's Avatar
10.01.2007, 12:45 PM
thanks for clarification Brain, oh mighty king of clarifying clarifications..
glassdoctor
TEAM FUSION
10.01.2007, 01:07 PM
What are you talking about... I thought Brian has seen my iron I use for building packs....
http://www.northerntool.com/webapp/w...70_47520_47520
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
