Brushless CRT.5 race setups. -
10.01.2007, 01:07 AM
Has anyone here raced their CRT.5 with the added weight of the brushless system? If so what are some suspension and diff setups that have been used that seem to work?
I am going to try next time at the track:
3k/3k/1k-Diff's
Medium (blue) springs with the one hole pistons and 60wt shock oil up front, two hole pistons with 50wt shock oil in the rear and medium springs. Front shocks in the number 9 hole & outer arm hole, rear shocks in the 9 hole & outer arm hole.
Mamba I will try 0 drag brake, 60% punch control, normal timing (Fiegao 7l 18t pinion and 2s 5000mah LiPo.
Thanks ahead for any input, just trying to see what other people have come up with that works.
