i guess i'm confused and need more info (a pic could help a lot too). how did it come apart? while driving? did the outside race just fall loose over the post? there shouldn't be any pressure from anything on that bearing...it sounds like it may be a defective bearing. contact robin or sam and they should get a replacement out to you.
one thing that could've caused a problem is too much loctite that may have dripped into the bearing...which will cause it to seize up. although you're saying it's a bottom bearing, which is less likely...
I have lost a total of 5 bearings in this thing so far. They just keep coming apart.
The guys at UE are just telling me I don't know how to install it properly.
i suspect if you get ceramic bearings, you'll just end up going through more expensive bearings. going through 5 bearings is a lot, and indicates something else is wrong besides the strength/quality of the bearings.
You should either ask Mike to get them for you, you know they are 5x8x2.5mm size bearings, right? or go to towerhobbies and check them out there. A good company that makes ceramic bearings is acer racing.
Nice to meet you!
