how similar are these balancers?
rschoi_75
Certified Spaceball
rschoi_75's Avatar
how similar are these balancers? - 10.30.2007, 03:20 PM
I was wondering how similar these balancers were:
- Hyperion LBA6
- Great Planes Electrifly Equinox:
http://www3.towerhobbies.com/cgi-bin...?&I=LXMGS7&P=7
- Orion Stability Balancer:
http://www3.towerhobbies.com/cgi-bin...?&I=LXNNA5&P=V
The reason I ask, is because I own a LBA6 and was wondering if I can mix and match the connectors from the balancers above for use with different branded lipo packs. Thanks for any help.
rcm xt8
rcm xb8
rcm crt.5
bluonyx
10.30.2007, 03:35 PM
They are the same, just rebadged hyperions. I'd have to say you get a better deal with the Orion because it comes with all the different adapters up to 5S. You should be able to miss the harnesses. At least I was able to with the great planes ones.
MetalMan
MetalMan's Avatar
10.30.2007, 03:53 PM
The units are the same, however the wiring harnesses that the Equinox come with are not Polyquest/Hyperion style. But Polyquest/Hyperion harnesses will plug into the Equinox.
rschoi_75
Certified Spaceball
rschoi_75's Avatar
10.30.2007, 04:25 PM
Much appreciated.
So I assume that the equinox harness will plug into my lba6 with no worries then. My goal is to use flightpower packs with my balancer.
I was hoping that this harness would be direct plug and play with my balancer:
http://www3.towerhobbies.com/cgi-bin...?&I=LXSEK4&P=V
rcm xt8
rcm xb8
rcm crt.5
johnrobholmes
johnrobholmes's Avatar
10.30.2007, 05:08 PM
You might need to rearrange the pins on it, but it looks like the same plug to me for the old hyperion balancer.
