Badlands and beadless question
highflier
Emaxx- FLM wannabe
Badlands and beadless question - 10.31.2007, 12:19 PM
This msg did not get a reply I suspect it got lost in the length of the other thread I had posted it in.
My wheels/ rims/ and adapters have shown up from Impakrc. The wheels come with a set of rings. It does not look like I need them but Thought I would double check before I assemble them.
Badlands
Maximizer beadless
So do I use the rings with this combo? The instructions indicate that they are option depending on the tires that you use.
Highflier
nl12
nl12's Avatar
10.31.2007, 01:29 PM
I have the same combo and I used the rings.
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
10.31.2007, 06:16 PM
Use the rings. The website says use the rings too. I have the same as well but I have the older style and have to use rage rings for the badlands.
This lists the tyres the rings are needed for:
http://www.maximizerproducts.com/max...ys_P187C35.cfm
highflier
Emaxx- FLM wannabe
10.31.2007, 08:08 PM
I have not been able to get the ring on the side of the screws. Thus I have 1 ring per tire on :(
Is there a trick to these things it is not easy.
Highflier
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
11.01.2007, 02:54 AM
I have the older version so I can't help you. Maybe nl12 can.
nl12
nl12's Avatar
11.01.2007, 07:40 AM
I have the new version now, I had an old version a long time ago and I think you just used one set of rings. Try contacting them here:
http://www.maximizerproducts.com/support/index.cfm
