MGM li-po low voltage cutoff???????
david lamontagn
MGM li-po low voltage cutoff??????? - 11.19.2007, 01:47 PM
I've a MGM 16018 and i've programm it with USBCOM+ (very easy!) and i've set the batterie type to 4s li-pol, but, i've don't see at any place in the user manual or in the program about a low voltage cutoff.
So could you tell me if the MGM 16018 have a li-po low voltage cutoff???
The only thing i can see is if i set the controler for 4s li-po, automaticaly the controler will cut the voltage at 12 volts.
But realy not sure because they not mentioned any information about it...
Thank you !
David
bdebde
That's All Folks!
bdebde's Avatar
11.19.2007, 04:26 PM
If set for 4s, and cut off set to cut off when voltage going down, it will give a cut off of about 3.1v per cell (according to MGM).
david lamontagn
11.20.2007, 05:41 PM
OK thank you!
sikeston34m
sikeston34m's Avatar
11.20.2007, 05:53 PM
Is that the MGM that's rated for 6 Lipo max? Sounds like it's very easy to program.
What motor are you using with it? I wonder if the MGM 12032 would be a good controller for my Revo?
Do they do well with outrunner motors?
Brakes and Reversible, all in a Car Controller! They look......hmmm...interesting.
