Well I just test ran it with the new pinion. I ran for 10 min in 35 degree weather, Just did WOT laps in my backyard, Ok not all Wide open it kept lifting the front tires and spinning out
After 10 min I broke a A-Arm
it was 20+ years old, So now I am waiting on parts from Tower, I am replacing it with a RPM A-Arm set.
Everything was nice and cool. I did not temp the items as I was inpecting damage to the vehicle. But I did touch them , I would say the ESC was 60, the Motor 70, and the batts were cold. So I am hoping that I have fixed the motor temp issue, Even if I raise everything by 40 degrees for summer weather I should be plenty fine.
I recharged the battery and it took 1900 MAH. I guess I had about 1 more min left in the battery.
Highflier
