MGM 16018 Cutting out at 1/2 to 3/4 throttle
bluesilver
MGM 16018 Cutting out at 1/2 to 3/4 throttle - 12.08.2007, 03:46 AM
G'Day I have just finnidhed installing a NEU 1515/1D motor in my Jato.
The Controler is a MGM 16018.
I am not sure if I am missing something, but when I reach about 1/2 to 3/4 throttle it just cuts the motor off.
Everthing is running nice and cool so there are no over heating problems.
I am only running 3s Lipo 5000mah batteries. Yet to try it out with 8000mah.
Doese anyone have any ideas on what is happening and how to go about getting full throttle out of it?
Any information is appreciated.
Serum
Serum's Avatar
12.08.2007, 04:18 AM
It might be the low voltage kicking in. You did set it on Lipo instead of nimh mode?
lilian
12.08.2007, 04:24 AM
Hello,
i've got the same with a 22418 and 1521/1d with flightpowers 4900 4s,
the only way for me to solve the problem was to put the controller on "low rpm" mode or "race mode"; don't know if the problem comes from a bug of the controller, or if it's just
that the voltage of the battery falls down under high loads (in this case my solution wouldn't be recomanded).
Let us know the results if you try with bigger batteries...
bluesilver
12.08.2007, 04:29 AM
Yea it is set up for 3s Lipo.
The battery was fully charged.
It will run at half throttle no worries, It is just when you give it full throttle the motor cuts out.
Bring it back to half throttle or less and it is away again.
It sounds a bit strange. Just thought I might of missed something in my programing.
(Programing by transmitter)
I have it programed to cut the motor off at low voltage but the battery still has 11.7V left in it.
Any more ideaa are appreciated.
Serum
Serum's Avatar
12.08.2007, 04:40 AM
I still suspect either the LVC (11.7V isn't exactly a fully charged 3S lipo pack) or a poor connection between the motor/controller.
things i would do;
-disable the LVC (what brand of batteries are you using?)
-Check the connections between the motor/speedo
-Check to see if the transmitters EPA is set to 100 percent
-reprogram
-try a separate receiver pack
-try a different radio
Serum
Serum's Avatar
12.08.2007, 04:42 AM
what does it do if you go from 0-full instantly? do you experience the cut-off too?
Happywing
12.08.2007, 10:48 AM
Yes, I would disable the BEC for testing. If that works, set it for 9v. 11.7v is too high for 3s.
bluesilver
12.08.2007, 05:53 PM
Thanks for the info.
I have it set for 9v cut off. the battery is at 11.7V only because I have been running around with it for a while trying to figure out what was going on.
Fully charged they are about 12.6V from memory.
The battery is a maxxamp battery.
I get the same problem if I go from 0- full throttle slowly or stright away.
I have just ben going over my instructions again last night.
It appears that I have missed a step in the programing ( programing by transmaitter)
Apparently I have to set the Automatics tunning when I have done everthing else.
It tells be to run the car at full throttle for a least 2 seconds.
Could this be the problem why I am not getting full throttle?
I can't try it out today as it is raining. will have to wait untill it clears up a bit.
Finnster
KillaHurtz
Finnster's Avatar
12.08.2007, 05:59 PM
Sounds like a LVC issue to me. You could always reprogram. Try it set to 6V and see if it works. The fact that it stops doing it in "race-mode" where all safeties are off tells you its a safety feature kicking in, and I don't think its a current limiter w/ your setup.
ncalenda
Need for Speed
ncalenda's Avatar
12.08.2007, 06:13 PM
I have the 16018, and found it will trigger the LVC early. I also have found that doing the auto tuning does help minor issues like this.
Finnester, you suggested to set it to 6v, how can you do that on the 16018? The only options we have is reduce speed, cut off and race mode.
  Send a message via AIM to ncalenda
Finnster
KillaHurtz
Finnster's Avatar
12.08.2007, 06:21 PM
You have to have some sort of settable cutoff. Option F isn't it for that one?
ncalenda
Need for Speed
ncalenda's Avatar
12.08.2007, 06:30 PM
These are the docs for the 16018.
I actually had thought I could set the LVC voltage and the BEC voltage, but you can't.
I ended up getting an external BEC, from castle and set it to 6v.
I still wish the LVC didn't cut out so soon. When I have it set to Cut Off, I used my voltage meter and I had @ 3.84 Volts per cell.
I wonder if when I run 5S, could I set battery type to 6S? Is that just used for the LVC?
bluesilver
12.08.2007, 07:15 PM
Thnaks for the info again.
I haven't set it to race mode as yet.
At the moment it is set on motor cut off when low voltage. ( should cut off at 9v) I think.
When you said to set it up for 6v to see what happens do you mean to set it up for 2 lipo instaed of the 3 lipo setting that i have it at now?
Serum
Serum's Avatar
12.08.2007, 07:24 PM
i think it's the LVC.. (where did i heard that before)
ncalenda
Need for Speed
ncalenda's Avatar
12.08.2007, 08:35 PM
The thing is, you can't set the LVC volt on the 16018, not the BEC voltage.
