Jconcepts gt2 body on CRT .5
entjoles
Jconcepts gt2 body on CRT .5 - 12.23.2007, 12:16 PM
got a new body for the little ripper!!
fit ok but had to cut out the rear shock tower area to get the body to fit low enough, also couldnt use the rear wing
i also used some bolink on road body posts i modified them to give extra height for the body
here it is......
and the rear shock towers...
btw....i still need to get some 1/10 truck size tires, the ones in the pic are the stockers
t-maxxracer32
t-maxxracer32's Avatar
12.23.2007, 12:37 PM
ya if you had bigger tires on there the truck would look freakin awsome.
sweet body though!
entjoles
12.23.2007, 12:50 PM
Thanks, i will be getting some new shoes for it soon, i used all my $ for a xt8 off ebay, so it will be a little while, but im in MN. so there is snow every where here now and cant bash
Serum
Serum's Avatar
12.23.2007, 12:59 PM
isn't it a tiny bit out of proportion?
entjoles
12.23.2007, 01:22 PM
the buggy tires really need to be replaced with 1/10 truck tires
unfortantly there arent many 1/10 scale bodies that really fit the ext. chassis
BlackedOutREVO
12.23.2007, 06:00 PM
why couldnt u use the wing?
will look awesome with 4in tires =)
entjoles
12.23.2007, 06:07 PM
the back end of the body hangs off the back to far, and high
BlackedOutREVO
12.23.2007, 07:33 PM
RCM Mike uses the normal gt body, so I dont see why the jc one wouldnt work....
entjoles
12.23.2007, 08:53 PM
i fits ok, but i could have had less issues if i would have mounted the body farther forward, but i wanted the wheel wells to line up as much as possible
the hood scoop made it diff. to mount the front so i added longer body posts all the way around
and yes, it will look much better with truck tires, i may also try a buggy wing mount, the crt positions the wing about 1" back from the rear axle so i would have to cut a huge part of the body out
cemetery gates
12.23.2007, 11:05 PM
Actually, at the bash, Mike had a PL crowd pleaser T4 body(shock tower bumps are in a different location than a rc10gt body). The shock tower bumps in the body lined up so you did not have to cut your body and the wing still fit.
Pic:
Bye
BlackedOutREVO
12.23.2007, 09:30 PM
Buggy mount?
Does it fit?
entjoles
12.23.2007, 10:51 PM
dont know if it will fit, and if i could get the crt.5 size wing on it, but i will try the one off my truggy when it comes, will more than likely look out of place(size)
BlackedOutREVO
12.23.2007, 10:56 PM
I pmed you
BlackedOutREVO
12.23.2007, 11:22 PM
He told me he has been using a RC10GT body...
You sure its a CP?
cemetery gates
12.23.2007, 11:31 PM
You sure its a CP?
Well, I have a rc10GT CP, and it really doesn't fit(have to cut holes for the shock towers to stick through). Also, the one Mike has in the pic looks different than the one I have too... and yes I'm sure its a CP....
Bye
