painted my new body
painted my new body
ncalenda
Need for Speed
painted my new body -
12.31.2007, 02:41 PM
What can I put to seal my paint job? I can scratch it off with my nail, which is not good.
ncalenda
Find all posts by ncalenda
2
david lamontagn
12.31.2007, 04:52 PM
Originally Posted by
ncalenda
Which paint are you using?? If it's Faskolor or Createx, use the Faskoat (manufacture by Faskolor), and put 3 coats, let it dry between each coat.
david lamontagn
3
ncalenda
Need for Speed
12.31.2007, 07:40 PM
I used this "
change paint
I did the pre-prep spray as is in the docs.
Can I still use Faskoat?
ncalenda
4
entjoles
12.31.2007, 07:43 PM
i had huge chunks of paint come off will i was trimming a body i painted with that stuff, i blamed it on not washing the body good enough
but it must be crap!
entjoles
5
ncalenda
Need for Speed
12.31.2007, 08:02 PM
I washed mine with soap, and none of the paint is falling off. I did have it fall off on another body, it was not lexan paint. If it is not clean, that could do this as well.
08:16 PM
ncalenda
6
entjoles
12.31.2007, 08:07 PM
sorry re-read post
i think once its backed , it should be ok then
i may have to retry this stuff then, i like the way it looks but didnt want to screw up again
entjoles
7
david lamontagn
01.01.2008, 10:56 AM
Before to paint a body, i always scuff it with scotch brite green pad, and wash it with dish soap and warm water.
And yes you can use faskoat on Spaz tix paint without any problems. Just be certain that your Spaz is dry before to back it with faskoat.
david lamontagn
Hybrid Mode
Switch to Threaded Mode
