2600 Kv rated motors? which one? -
01.06.2008, 09:13 PM
okay so i was looking at the Ammo 36-56-2600 for my race spec revo. tekno used a neu 1512/2d motor(2600Kv) and the mamba max controler, which is the same kv rating and esc that i was going to use. i was wondering if there was a nemesis or feigao XL motor with a 2600Kv rating(or similar 2500-2700). it will be run on 3s lipo and set up to race. cant afford the neu, or any motor that cost more than $120 so if someone could point to a feigao or similar motor that be great. thanks
You could also use a Feigao 7xl at 2382kv and gear it a tooth or 2 higher. The larger motor should allow the taller gearing no problem. Thats probably your best bet IMO. http://www.rc-monster.com/proddetail...WAND_XL&cat=20
to make it...
or break it...
ok thats cool then. and i could gear that probly 18/36 instead of the 18/38 i planned and get about 35mph speeds like i would with the 2600 ammo? is there another motor out other than the neu that would get about 2600 Kv?
okay well like i said before i cant put much mroe than $150 into the motor. so a feigao 7xl or 6xl both on 18/36 gearing will give me about 35mph speeds and wheelies all over the place? thats what im looking for. enough torque to rip the wheels up, and fast enough to be a track truck on 3s lipo. and no i cant bore out the tekno electriclutch thingy. i dont want to try atleast. any other inexpensive but crazy powered motors out there?
