Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Best Cooling Fan for Mamba Max?
sikeston34m
sikeston34m's Avatar
Best Cooling Fan for Mamba Max? - 01.22.2008, 09:21 AM
What's the best fan to get to mount to the Mamba Max heatsink?
Now that Castle has updated the firmware for the MM, which promises better startups, I plan on testing the MM again.
It's time to see if it will run 12 pole outrunners. I know the little booger tends to run hot though.
I remember seeing a small fan (25mm) or so that would mount directly to the heat sink.
Anyone remember where to get that?
BL-Power
BL-Power's Avatar
01.22.2008, 09:44 AM
Here you can find a 25mm fan: http://www.rcmart.com/catalog/produc...ducts_id=20590
and here a 30mm fan: http://www.rcmart.com/catalog/produc...ducts_id=21971
I was using the 25mm one my Mamba Max for a long time, with it my MM never got hotter than 125f.
 Send a message via ICQ to BL-Power
jhautz
jhautz's Avatar
01.22.2008, 09:59 AM
I was using a 5v 25mm fan from allelectronics.com but they dont seem to have it any more.
The 25mm fans fit the heatsink perfectly and the one BL-P linked above looks perfect.
to make it...
or break it...
Silent...But Deadly
DrKnow65
DrKnow65's Avatar
01.22.2008, 10:45 AM
Here's the one I use from digikey.com, it's 25x10mm and 3.5cfm, @5v (highest cfm I've found). $11.47 plug some shipping. Runs realy well on 6v too.
http://search.digikey.com/scripts/Dk...me=259-1325-ND
01.22.2008, 11:01 AM
I use 25mm 5v fans from the fanvan on Ebay - I also run 2 on the RCM feigao motor heatsink...
I think I use the stampede rear body mount support screws which fit great into the MM heatsink.
01.22.2008, 11:53 AM
This is the best fan I have seen: novak 25mm fan. I just plug it into the rec and bolt it to the mm heatsink with m3 machine screws. I also space it off the heatsink 1/4" or so, that seems to help flow and cooling. Or send it to Artur and have him do the stage 1 mod. That cured my heat issue and ran fine with a 7xl on 4s in a heavy 1/8 buggy. With the new software and his mods I have a feeling the MM may work with outrunner and high loads better!
dezfan
01.22.2008, 04:25 PM
This is the fan I intend to run on my MM, It's a 25 x 25 x 10mm fan w/ a 3.5 CFM rating. Under $15.00 shipped.
http://www.hardwarecooling.com/produ...5x25x10mm_Fan?
01.22.2008, 04:48 PM
That is what i use but they are 4.99 on fleabay from fan van
MetalMan
MetalMan's Avatar
01.22.2008, 05:15 PM
It's not one of these, is it?
http://stores.ebay.com/The-PC-Fan-Va...QQftidZ2QQtZkm
bdebde
That's All Folks!
bdebde's Avatar
01.22.2008, 09:58 PM
I like using the 12v models right off of the lipo (4s), you can attach the fan leads right at the circuit board on the MM and keeps the tiny wires out of harms way.
01.22.2008, 10:04 PM
metalman - thats it
dezfan
01.22.2008, 10:08 PM
The fans on FanVan are only producing 1.3 CFM @ 7000 RPM on 5v.
The one I listed produces 3.5 CFM @ 13000 RPM on 5v.
The price on the e-bay fans is very good, but the higher rated one isn't that much more expensive.
01.22.2008, 10:13 PM
Thanks i'll note that for next time if these go...
rchippie
rchippie's Avatar
01.22.2008, 10:18 PM
I use these fans.
http://www.primelec.com/Shop/Control...id/0/SFV/31734
REAL MEN RUN BRUSHLESS
dezfan
01.22.2008, 10:22 PM
Wow, it those numbers are accurate, they would be a serious contender at $3.49.
5VDC
Dimensions: 1.60"W x 1.60"H x 0.80"D
8.6CFM
Ball bearing
Current: 700mA
Power: 2.0 watts
Noise: 36dBA
2.5" Lead wires with Bare ends
