battery size
Revo_crazy231
Devin
battery size - 05.07.2007, 10:19 PM
http://www.maxamps.com/proddetail.ph...-10000-74-Pack
will this battery be:
-6 in. long (estimate)
-2 inches wide(estimate)
and
-.86 inches ??? (idk let me know)
also if these dimensions are wrong can you please let me know or help me
thanks so much
  Send a message via AIM to Revo_crazy231
jhautz
jhautz's Avatar
05.08.2007, 12:11 AM
Just take the mm dimensions listed and divide them by 25.4 and thats the inch measurement.
They are 2.32" x 6.22" x 0.866".
to make it...
or break it...
Silent...But Deadly
05.08.2007, 12:12 AM
The specs list it as:
59mm wide X 158mm long X 22mm thick.
Converting to inches is simply a matter of taking mm and dividing by 25.4. So, in inches:
2.32" wide X 6.22" long X 0.87" tall.
Since you are probably looking to make a battery tray, you want to estimate a little higher (and don't forget padding thickness if you use it). So, rounding the figures up a tad, that's:
2+3/8" wide X 6+1/4" long X 7/8" thick.
EDIT: jhautz beat me to it!
AAngel
05.08.2007, 12:13 AM
Yeah, them cells is BIG.
Revo_crazy231
Devin
05.08.2007, 06:55 AM
thanks for all the replies and yes i am trying to make trays
-good point on oversizing the trays thanks
-and are these rather big like aangel said or are these about average for this size lipoly batteries??
thanks again,
crazy
AAngel
05.08.2007, 09:52 AM
I suppose it's a matter of perspective, but I find them to be quite a bit larger than the average size pack. A battery tray hanging an extra .3 or .4 inches over the side of your chassis for a good 6" run is a lot. If you are putting them in a truck, you could always just stand them on their side, if your configuration will be wider than it is tall.
