zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.12.2007, 12:53 AM
What are the capacity on the stock MM caps? are they 270uF each? Or are they just a smaller package?
05.12.2007, 12:59 AM
IIRC, 220uF 25v.
AAngel
05.12.2007, 01:10 AM
suicideneil, that's dirt. We run on the stuff at our track.
zeropointbug
Z-Pinch racer
05.12.2007, 01:15 AM
hmmm, I wonder if you replaced those caps then with just the caps you bought, if then it would be capable of 6s? They do use the same FET's as the Quark right?
BlackedOutREVO
05.12.2007, 01:20 AM
or atleast run 5s without getting fried
zeropointbug
Z-Pinch racer
05.12.2007, 01:27 AM
Yeah, even making 5s work flawlessly/reliably would make it 'the' controller for the average basher.
Also,(i've asked before) I want to get this custom Quark case designed, does anyone know: (in mm, 0.01 decimal point)
-width of the Quark PCB board?
-distance from bottom surface FET's to top surface of FET's (I want to clamp the power stage board in the case, and thermally coupled to it)
BlackedOutREVO
05.12.2007, 01:37 AM
average basher?
id say most ppl, its already i think the most used speedo, all i see is a mm speedo in everything. they ROCK!
zeropointbug
Z-Pinch racer
05.12.2007, 02:19 AM
I say 'average' because they can't run Neu motors very well apparently. But then again the Quark has even more trouble with what it's rated for... hmm, 6s. :005:
BlackedOutREVO
05.12.2007, 02:23 AM
ohh yeah true true
i forgot about that part
A4DTM
05.12.2007, 01:28 PM
zero, I got 27.14mm for width, but have no way of measuring the fet distance.
zeropointbug
Z-Pinch racer
05.12.2007, 02:58 PM
Thanks, I actually am playing around on CAD right now, and I used 27mm (I went back in the forum and checked the heatspreader width of BrianG).
Also, I am using 5mm for FET to FET, but these are just guesstimates, as this is just a sketch; I will post a screenie in an hour or so. An accurate one is going to have to wait for my Quark to get back from S&T.
ZPB
AAngel
05.12.2007, 07:00 PM
I dropped all of the capacitors into the mail today.
zeropointbug
Z-Pinch racer
05.12.2007, 07:04 PM
You're a good man AAngel. :027:
The post-office is open today? :032:
ZPB
05.12.2007, 07:06 PM
Ah, just looks a bit reddish... my eyes dont function as well as they should.:025:
MetalMan
MetalMan's Avatar
05.12.2007, 10:41 PM
EXCELLENT!
ZPB
It is, in the U.S. :).
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
