zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.17.2007, 01:46 AM
Here is a pic of what it more would like assembled (with stock plastic covers of course).
Name:	Quark case v 3 5.PNG
nieles
nieles's Avatar
05.17.2007, 05:22 AM
cool but what about an version without the slots for cooling but solid aluminum
this will make the case significant cheaper
or only slots on the under side is also enough for me
  Send a message via MSN to nieles
Patrick
Patrick's Avatar
05.17.2007, 06:05 AM
Originally Posted by zeropointbug
Also: Does anyone know the dimensions of the RC-Monster heatsink, the length?
Thanks
Mine is 84mm long.....the heatsink, you dirty minded people.
That design is looking pretty good, if it has a flat bottom then it would be good for mounting to the chassis of a 1/8th, but then if it had fins on the bottom and mounting holes on the end there would be one less thing for an e-maxx driver to buy. Personally I have the RC-Monster heatsink already, and I have a 1/8th that I will want to put the Quark in soon, so I like the flat bottomed version with screw holes underneath.
zeropointbug
Z-Pinch racer
05.17.2007, 11:22 AM
Geez, I was hearing that ppl would rather have integral heatsink on bottom? You will still be able to mount the bottom on anything, it is flat heatsink, no problem there.
I will see how much a heatsink bottom will cost, and one with flat bottom.
thanks Patrick
Maxxman
05.17.2007, 01:20 PM
hey i have got to say that it looks great.
would be interseted in getting one if the price was right.
ssspconcepts
ssspconcepts's Avatar
05.17.2007, 01:43 PM
SSSPCONCEPTS:
Would you rather have the flat bottom, so you can use RC-Monster heatsink/mount.
Would you rather have integral heatsink on bottom w/ mount screw holes on each end of case?
Thanks
I like an integral design.
zeropointbug
Z-Pinch racer
05.17.2007, 08:05 PM
Yeah, me too. I think it's best keeping to one design, and integral is my middle name.
This is what an R/C MT esc should be with this heatsink, the Quark... even if S&T made the top set of FET's coupled to the chassis, that would be worlds better.
CAD program says the outside surface area is roughly 300cm2. That should do the trick. :017:
So maxxman, nieles, ssspconcepts, patrick, A4DTM, jhautz are you guys seriously interested in getting one for yourselves?
Again, the design is not to specs, I don't have my Quark back yet from S&T, so it's going to have to wait for it to get here.
Does anyone happen to know a free thermal simulator program that I could use on this case?
ZPB
Maxxman
05.18.2007, 02:17 PM
sorry,
no idea's about the thermal simulator program, but if the price isn't sky high i may get one, as they look sick!
there was going to be some room for some extra capaciters wasn't there.
You say that the outside surface area is around 300cm2 but i was wondering what the surface area was on the original one.
Thanks.
zeropointbug
Z-Pinch racer
05.18.2007, 02:36 PM
The more ppl we can get, the cheaper it will be per unit. Mike still hasn't replied back yet though.
The stock Quark case is roughly ~60cm2, but also the thermal coupling between FET's and case is very poor. So this one has 5 times the surface area plus superb heat transfer from top and bottom FET's. I can bet under normal MT conditions the FET's will only get 10 degrees (maybe less) warmer than ambient temp, but just a guess.
Oh, there is no way I can make room for extra caps on this, it would simply be too large. Caps are going to have to be added to power leads externally.
Maxxman
05.18.2007, 02:43 PM
try e-mailing him again
i e-mailed him some time last week maybe thursday and got no reply.
So i sent it to him yesterday and he came back today. he also told me that he was having,
"a few struggles with the site lately(wacky computer/web stuff that I am largely unfamiliar with) – I apologize for delays in response relating to this."
i am still wondering if therewill be any room for extra caps.
A4DTM
05.18.2007, 04:21 PM
zero, sorry, I'll send you my files when I get home tonight. I'm still playing w/ the design some, here's where I'm at now.
I don't have time to mess w/ it right now, but do you know if COSMOS will do thermal simulation?
zeropointbug
Z-Pinch racer
05.18.2007, 04:44 PM
That's alright, you don't need to send them. I think the design I am at now is pretty good, I'm trying to keep in mind CNC work, keeping the actual bit/flute in mind. Keeping it relatively simple
I really, really like your design, but the top cover will add a lot more cost to it... :030:
BTW, what are you using to render your parts? Is it built into your CAD?
zeropointbug
Z-Pinch racer
05.18.2007, 04:47 PM
What mount is that it is on?
A4DTM
05.18.2007, 08:49 PM
haha np, sorry for the late reply. I'm not planning on getting a new case for my quark, as it's already 1/2 blown lol.. I'm just waiting for it to die, then I'll go Teken or CC. I just enjoy modeling, and I figure I can use stuff like this in a portfolio. I've designed alot of stuff that I'll never get made, simply because it'd be way to expensive for me. Here's a perfect example of a project that I really enjoyed designing, but would cost me an arm and both legs to get made: http://www.rc-monster.com/forum/showthread.php?t=1421
I'm using PhotoWorks to render, which is built into SolidWorks. I've got quite a few other renderers, like Maxwell Renderer, with a plugin for SW, so you still render in SW, but it uses the Maxwell engine. as well as Brazil R/S, V-Ray, and Electric Rain, but those, I need to export the part, and import it into 3DSMax, and depending on the renderer, I need to use different versions of 3DSMax.. so I havn't played with them yet. Maxwell works in SW, but my machine's not up to snuff for high quality renders, so it tends to crash SW on me..
The motor mount is from my XR8 project. Here's that thread: http://www.rc-monster.com/forum/showthread.php?t=3489
zeropointbug
Z-Pinch racer
05.19.2007, 03:13 AM
Cool, I like the chassis design.
Yeah, I guess you can't even get your Quark board out of your case right now! :eek: Too bad.
maxxxman: There will be no room for extra caps inside the case.
