Got Revo!!
nbcaznmaster
RC-Monster Cult Member
nbcaznmaster's Avatar
Got Revo!! - 07.11.2005, 07:41 PM
I got a revo! i WAS going to convert it to electric but...the high prices of brushless stopped me dead in my tracks. Ima keep it nitro for a while and maybe i'll conver it when Mike gets the converstion kit out!
  Send a message via AIM to nbcaznmaster
nbcaznmaster
07.11.2005, 07:43 PM
that last post bumped me up to 50 posts!!! DISCOUNT TIME!! Too bad i cant use it.. Any1 wanna buy my discount?!?!?
Serum
Serum's Avatar
07.12.2005, 03:24 AM
If you ever need something for your Revo you can the discount..
Do you like your revo? quite fast allready isn't it?
mayham st man
10.21.2005, 11:57 PM
get the .18 tm it is super fast I blew away a hpi savage with the sirio30 it was not a pleasent scean my revo killed his ass
squeeforever
squeeforever's Avatar
10.22.2005, 01:12 AM
the only bad thing about the tm is that the bottom ends dont hold up to well. the tz is what ima get for my revo.
crazyjr
crazyjr's Avatar
10.22.2005, 04:51 AM
Hey Squee. Thats not just a TM problem. They are having the same problem with the TZ and I have a OS 12CV-X (little red head engine)and it has the same problem here it is discussed at length and they have a solution to the problem. I would suggest you read up on before you get the engine of your choice. I'm not telling you to not get the engine, i'm just suggesting you need to read and get this product when you do.You need to read the first two to four pages to understand what is going on
nbcaznmaster
10.22.2005, 07:41 AM
WOW, some revived this dead thread! lol, even at 50 posts i tried to sell my discount! ahahaa.
squeeforever
10.22.2005, 10:53 PM
thanks crazyjr. glad you pointed that out. i wouldnt be able to afford another rebuild. i just rebuild my trx 2.5 that only had a gallon and a half on it. so is that spacer needed, or able to be used if you plan on running a pullstarter
mayham st man
10.23.2005, 12:07 AM
wrong the tz dont have bottem it oley has top end:L:
squeeforever
10.23.2005, 10:33 AM
so which is a better choice? tz or tm?
mayham st man
10.23.2005, 04:54 PM
tm all the way my cousin got the tz the same time i got tm and his already blew up and mine still runs.
squeeforever
10.23.2005, 05:22 PM
which is faster though? not to mention, that spacer will help. if you dont have it chances are yours will need a rebuild to. i need all the power i can get cause i race.
tm
mayham st man
tm - 10.23.2005, 06:40 PM
On the track my rpms stayed up alot more, because of bottem end so the tz is not the best engine for racing i would go with tm. even whene he messed with the spacer it still did no good. now he bought the mach .26 and has no top end but he pleant of bottem end. the tm is all around good engine everybody has tm at the hobbie store i race at.
crazyjr
crazyjr's Avatar
10.23.2005, 09:15 PM
If he uses the electric or pull start he will be fine. The problem arises fron the gap between the piston and rod, when the rod moves out away from the crankshaft it grinds on the backplate and the channel in the crankcase where the rod travels. If you have a electric or pull start the piece that turns over the enginewill keep the rod in place. However if you convert to bump start you take away the one thing that keeps your rod from destroying the engine
squeeforever
10.23.2005, 10:03 PM
yes, that is true. so i guess i wont need the spacer then? i plan on running a rotostart or a pullstart. starterbox is a little pricey for now.
i dont know why but everybody says that the tz is a MUCH faster engine and that it is the best engine for a revo. not to mention that everybody at my local track runs it. which one to get???? if im not mistaken, the tz makes more horse power and it is said to be "the ultimate smallblock".
