pinion slip -
06.01.2007, 12:20 AM
i guess this is a newbie question but i for what ever reason am having a hell of a time getting pinion gears to stay put. I have tried the set screw alone. I have tried locktite on the set screw, i have tried the locktite on the shaft. I have tried locktite on the shaft and the set screw haha.. other than grinding a flatspot on my motor shaft what are some other ideas or tips comes to attaching these large mod 1 size gears.
ps: tony i know you will see this. ill take pics of mug as soon as my fans come in. you'll dig...
06.01.2007, 12:22 AM
With the instant torque delivered by these brushless systems, grinding a flat spot is almost mandatory. About 30 seconds with a Dremel is all it will take...
That's All Folks!
06.01.2007, 12:29 AM
GOTTA do the flat spot!
06.01.2007, 12:41 AM
Yep, no flat spot = no grip. What I usually do is remove the rotor from the motor, shove the shaft through a plastic bag, stick the other end of the rotor in the vice, and dremel a flat spot along most of the length of the shaft. If I can't get the rotor out, I still use the bag, but I attach the three motor leads together (to help keep the rotor from spinning), and lay the motor in the vice (but don't clamp down on it). So far all of my flat spots look incredible :005:.
That's All Folks!
06.01.2007, 12:50 AM
I just taped up the end of the motor with just the shaft poking through, grabbed hold of the shaft with a large skinny set of hemostats (AKA roach clip), then took a dremmel to the shaft as I held the motor and hemo's on the table. Got a perfect flat spot!
06.01.2007, 12:58 AM
Wow, you guys go through greater lengths than I do! I just tape the motor holes, grab onto the shaft with my fingers and dremel away. However, I do dremel so the wheel spins along the shaft so it doesn't try to spin it.
06.01.2007, 06:04 AM
ah ok .. i was worried that it may terminate a bearing by being unbalanced but it seems like its a non issue. thanks
06.01.2007, 06:30 AM
i had to use flat spot (just taped the motor) + blue loctite. without loctite no chance
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
06.01.2007, 09:50 AM
If you are worried about balance issues, just remember that the set screw helps offset the imbalance caused by grinding the shaft. In fact, you probably have more imbalance if you DONT grind the flat spot because of the set screw...
06.01.2007, 03:38 PM
... which could cause slight vibrations leading to the set screw loosening up.
Z-Pinch racer
06.01.2007, 08:54 PM
Ideally, if you KNOW what gearing you are going to use, I would drill a counter-sunk shape hole into the shaft for the set screw to sit inside. That would be the best hold, IMO. I have not done this however, just a thought.
06.02.2007, 02:55 AM
This is what i do; push the shaft through a plastic bag, and wrap the rest of the bag around the motor. don't push your dremel too hard, and a small notch is all you need.
Z-Pinch racer
06.02.2007, 03:19 AM
Yeah, same, I took the rotor out of the motor, and pushed the shaft through wide masking take and wrapped the rest back over the rotor to prevent filings from being held on.
06.02.2007, 04:00 AM
Why would you take the rotor from the can? this only increases the risk of damaging and it's more exposed than it is in the can.
06.02.2007, 10:10 AM
The 'crater' works good for me. I make a short, shallow flat spot, then bore in a dimple with the tip of a dremel grinding stone. (I just grab a dremmel and a motor and go at it. yes grind at right angle so the shaft doesnt spin.)
I then blow off any metal dust that may have stuck. (I'll do a plastic bag next time :) )
I do not like long flat spots, they unbalance one end and make the shaft wobble. Also, I use the motor fror braking and a flat spot always seems to leave a little 'play' and this ALWAYS loosens the set screw for me.
This with plenty of LocTite is the ONLY thing that works for me so far.
Linear Mode
