jnev
jnev's Avatar
06.22.2007, 11:07 PM
I was also planning on waiting for the MMM. But finally decided to go with the MM from everyone telling me to.... and I didn't regret it. It works great on 4s with a UBEC. I am not scared any more of possibly frying it. I think it will run strong for me for a long while.
crazyjr
crazyjr's Avatar
06.22.2007, 11:31 PM
it is a very solid esc, I still run mine in 1/10 apps. Just needed something stronger and more efficient that MM in the MT and 4pole motor area
gasshead
j-womp
gasshead's Avatar
06.22.2007, 11:46 PM
thanks RC for the reassurance, it seems that u were in the same boai as i.
and crazy jr what do you meen by a solid ESC? and what is a 4 pole motor
  Send a message via AIM to gasshead
gixxer
gixxer's Avatar
06.23.2007, 11:36 AM
if out of warranty they will just charge you $50 to repair it.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
crazyjr
crazyjr's Avatar
06.23.2007, 12:09 PM
I mean its a great esc, always does great when pluged in and despite some programming problems (v2.23 castle link software) it has never let me down
gasshead
j-womp
gasshead's Avatar
06.23.2007, 01:11 PM
what type of programming problems? as i strated before i am a total noob to this Bl setup. and does the v2.23 castle link come with the ESC?
i mentioned this to one of the guys at my LHS and he tod me that i would be looking at some major over heating problems, is this true and could it be fixed with a fan of some sort? i do have a rather large fan out of a powersupply but it is prolly to big, maby some 40mm style ones.
AAngel
06.23.2007, 01:18 PM
Don't listen to anyone telling you about how to run brushless, unless you are sure that they know what they are talking about. The LHS is usually the worst place to get brushless advise, especially when it comes to large scale.
The Mamba Max is a good controller. Just don't try to make it do what it doesn't want to. Don't go over 4S lipo. Some will do 5S, but that is pushing it. Stick with two pole motors. The MM doesn't like four pole motors.
If it starts to run a bit hotter than you'd like, try a fan. Fans are good for dropping the temps a bit, but are not a fix or overgearing situations.
gasshead
j-womp
gasshead's Avatar
06.23.2007, 01:21 PM
thanks AAngel, if you dont mind could you explane the diffrence in 2 pole and 4 pole motors, i would likt to run a feagio 10XL, would that b ok for the MM?
06.23.2007, 01:31 PM
A 2 pole motor has one norht pole & one south pole on the rotor magnet, whilst a 4 pole has 2 norths & 2 souths, IE: north-south-north-south. This means the esc has to work twice has hard to make the motor rotate, but I believe this equals a much smoother motor & less cogging, or something to that effect. The programming is different for a motor with more poles since the esc has to do extra work to get it to rotate, and since the MM motors are all 2 pole jobbies, the MM esc doesnt like 4 pole motors. Castle is ment to be releasing a programming fix for this issue but it is unlikely to happen until after the MMM is for sale, other wise people could run the brilliant Neu motors on the MM, so wouldnt need the MMM unless they wanted an insanely powerful/fast system.
gasshead
j-womp
gasshead's Avatar
06.23.2007, 01:37 PM
thanks. i am still going to have to save my pennies to get a system. but all of this positive ressurance i am getting from you guys is exxalent. makes me rethink the parts list i had made up. you did however mention cogging, would i run into this problem with 12or 14 sanyo 2400 nicd cells? i know i know i need to have nimh but these were a gift a while back but i didnt have any thing to put them on.
AAngel
06.23.2007, 01:47 PM
The Feigao is a two pole motor and running the MM with the 10XL on 4S lipo, won't give you the fastest setup, but it will be dependable and torquey. It would do nicely in a monster truck with big tires on it.
06.23.2007, 01:53 PM
cogging isnt so much to do with powersource, more about gearing & running at quite low speed, since the esc has trouble 'knowing' where the rotor is.
Ebay?:005:
gasshead
j-womp
gasshead's Avatar
06.23.2007, 01:59 PM
man i dont want to put nice batteries on fleabay.....and they should be fine until i go to lipo
jnev
jnev's Avatar
06.23.2007, 02:17 PM
http://www.rc-monster.com/forum/showthread.php?t=7277
gasshead
j-womp
gasshead's Avatar
06.23.2007, 03:50 PM
that threas, smoke no fire(yet), has now got me worried. if i do the MM would i run the risk of that happening?
