09.11.2007, 05:09 PM
I'll try to get some pics but I dremmelled more than most in order to get the trans as straight as possible.
Just lined it up and started cutting. The existing trans mounting holes don't exactly line up so need a little modding there - I ended up almost cutting "channels" for the other 4 mount points.
I also run the titanium skid too - At some point I have a whole new chassis (all of $10 for a 2.5) that I was going to have another go with - But at the moment its is a case if it isn't broke leave it alone (i.e. just wait a week or two until you break it!)
hey
hey - 09.11.2007, 06:00 PM
the evx is good for 14 cells, one of the first threads you stated it's only good to twelve, it handles 14 all day, and you DO NOT need a bec with an evx, especially with titan motors, makes your install alot easier, also, i run a lever on my e-maxx tranny for shifting, it requires me to bring the truck to me when I need to shift, but it eliminated the servo, and i'm either bashing or hill climbing, so I know what gear I need. get yourself some 7 cell packs and wake up those titans a little!
rchotrodz
09.14.2007, 12:18 PM
well I just started dremeling the chassis last night and so far so good I just need to cut the holes for the mounting points for the trans...
rchotrodz
09.15.2007, 10:52 AM
here is what I got so far...
ID:	3243   Click image for larger version
ID:	3244   Click image for larger version
09.15.2007, 05:50 PM
"Can ya tell what it is yet?"
Try test fitting the centre shafts, and you will see if you need to remove any material on the chassis around the rear output shaft of the tranny (thats the main area of concern usually).
rchotrodz
09.18.2007, 01:49 AM
yupp you are right suicideneil right at the rear the pins on the shaft hit the chassis preventing it to turn... Thanks
rchotrodz
09.20.2007, 01:33 PM
well I did dremel off more of the chassis like suicideneil had mentioned here is the new pic with one battery holder mounted
09.20.2007, 05:41 PM
So far so good. Clever use of an old Emaxx chassis there, will look semi-factory with both battery holders mounted (if thats the intention). Just make sure they're bolted to the existing chassis really well, wouldnt want them to separate at speed....
09.20.2007, 08:53 PM
Wow! You didn't need to cut anything off the rear - where it was rubbing you just needed to use the grinding wheel to shave off a 1mm or 2. That's quite agressive - hopefully won't hurt the chassis too much.
I'd round off your cuts to stop stress risers.
Cheers
rchotrodz
09.22.2007, 11:39 PM
well here are more pics of my project build
ID:	3261   Click image for larger version
ID:	3262   Click image for larger version
offroader
09.22.2007, 11:46 PM
Have you had a chance to test this with the Titans? You might want to consider BL motor if you can't get the speed you want.
09.23.2007, 09:12 AM
I have a funny feeling this is how the E-revo will look , more or less, when/if Traxxas ever get their finger out and build it. You may want to add a guard to that steering servo- looks a little exposed sticking out the bottom like that (just as it does on a stock revo/maxx). This is another one for the books I reckon, another unique creation.
rchotrodz
09.23.2007, 04:17 PM
thanks suicideneil I was planning on doing that and a guard for the tranny as well
rchotrodz
09.24.2007, 02:18 AM
Here is my finished E-Revo minus the guards I would love to get a video of this monster in action but I have no way of getting it to the computerbut oh well it is mostly finished and I can run it
Thanks for all of the help....
ID:	3306   Click image for larger version
ID:	3307   Click image for larger version
09.24.2007, 12:03 PM
Wow, you finished that amazingly quickly, I think its a testament to how simple the chassis is to work on and how interchangeable parts are between vehicles (with a little filing here and there). Nice work & go enjoy the fruits of your labour!
